Thread started 29 Dec 2006 (Friday) 06:11
Red Pod
tumblew33d
Dec 29, 2006 06:11 |  #1
I bought some extension tubes recently and decided to add a red 'The Pod' to my order as it was reduced and looked handy.
I've read a few other's comments about it and see that some even use it with long lenses (400mm was mentioned in one post).
My question is: How?! I tried it with my Tamron 17-50 mounted and it flopped fowards. I even removed around 1/3 of the plastic filler beans which helped a bit, but I still found it tricky to position where I'd like.
I might try filling it with steel bearings to give it more weight. Any other suggestions on how to use it successfully?
buddy4344
OM System Ambassador
Gallery: 412 photos
Best ofs: 14
Dec 29, 2006 08:17 |  #2
I got a "big red" for christmas. I have been using with my 100-400 IS shooting through the car window (practicing for an upcoming safari). I attached a monfrotto quick disconnect to the pod and to my foot of the big lens - and also removed some of the "beans". It seems to work well for me - but still learning how to optimize positioning.
Buddy
Buddy4344
OM System Ambassador, Gear: Olympus OM-1 and EM1X, Olympus/Zuiko Lenses: 150-400mm f/4.5, 40-150mm f/2.8, 12-40 f/2.8, Oly 2x and 1.4x TCon, Kiboko 30L and 22L+
tumblew33d
Dec 29, 2006 08:32 |  #3
Aha, I see. So you're holding the camera and using the Pod as a rest. I had hoped that I could use it as a support in situations where I can't use my tripod.
Pinto
Always in our hearts and minds. R.I.P.
Joined Jan 2005
Dec 29, 2006 09:50 |  #4
tumblew33d wrote in post #2459142 (external link)
I think it was designed to be only a rest, and it works quite well in that capacity. I would never attempt to leave a camera unattended on it.
tumblew33d
Dec 29, 2006 10:59 |  #5
Pinto wrote in post #2459464 (external link)
Like this? :eek:
I didn't plan on precariously balancing it on a post like this, but I had hoped it'd allow me to position my camera on a table or wall. It's fine with lighter lenses, it sits perfectly with my 50mm attached. I just wondered how people used it with longer, heavier lenses.
Pinto
Joined Jan 2005
Dec 29, 2006 14:09 |  #6
Brave ??? man!
757 views & 0 likes for this thread, 3 members have posted to it.
Red Pod
1939 guests, 129 members online
