Hi all
I've been reading this forum for a while but never posted. I got a 30D a couple of months ago and I'm still trying to get used to reading the exposure meter, hopefully someone can help me out
Basically my problem is that when I'm in manual mode using flash in dark environments, the meter is pretty much useless. Even if I'm in spot metering on the face of a subject, the camera tells me I'm underexposing though the subjects are well exposed with flash once I take the shot.
This means that I end up ignoring the meter and taking test shots, then looking at the screen and the histogram to judge exposure. In places where the lighting is different throughout the room this means I'm reviewing and adjusting FEC all the time...as shutter speed can't get any lower (usually 1/80 to 1/125 depending on how much background I want) and aperture is the minimum necessary for acceptable depth-of-field. Adjusting the ISO does affect the metered values but then my subjects get too bright though the background is better (again, even when spot metering on their faces)
Soooo my question is....is this normal? Is there a better way to use the meter under difficult lighting conditions?
