Thread started 01 Jan 2007 (Monday) 16:42
Canon S2 - Preserving Function Settings?
ellis800
Jan 01, 2007 16:42 |  #1
Is there any way to tell this camera to remember Function Menu selections? Seems like this should be easy to do, but I can't seem to find anything in the documentation.
Getting frustrating to take time setting up the camera for lighting/scenes/whatev​er, then the it goes to sleep and I have to start all over again...
cor
Jan 02, 2007 16:48 |  #2
That is what the C mode is for I believe.
dale500
Jan 03, 2007 00:06 as a reply to  @ cor's post |  #3
Set the camera dial to "P". Adjust all the settings on all the menus to just where you like them. Tab down to the bottom of the main menu till you see Save Settings. Hit the SET button, select OK, and hit the SET button again.
To use your settings turn the camera dial to "C" and you are ready to shoot. You can even adjust different settings during the shoot but when you turn the camera off and then back on again all of your original saved settings are back.
It is one of the coolest yet probably least used of all the S2 functions. It makes it super easy to always start out with the same initial setup each time you turn on the camera.
Dale
Canon S2
Dale
S2 IS, SX40HS, Rebel XT + Grip, 18-55is, 55-250is,
ef 35-135mm push/pull, 500t closeup, Moose Polarizer, 380ex
ellis800
Jan 03, 2007 08:40 as a reply to  @ dale500's post |  #4
Thanks guys, sounds right on the money.
956 views & 0 likes for this thread, 3 members have posted to it.
2193 guests, 128 members online
