Thread started 02 Jan 2007 (Tuesday) 01:48
Lens distortion / softness question
Stearmandriver
Joined Jun 2005
Jan 02, 2007 01:48 |  #1
I imagine this is a dumb question. It's the first time I've ever tried to objectively test out a lens though, so I'm not positive what I'm seeing here, and was hoping someone could tell me.
The following three shots were taken with a 28-135 f/3.5-5.6 IS USM lens, at 135mm, with the box only about 12 inches from the lens... in other words, the lens was focused almost at its macro stop. They were taken at f/5.6, f/8, and f/16, respectively. Focus point was the big "6" in the center:
Yes they're underexposed and glarey... just going for a quick and dirty comparison here. Notice the marked decrease in sharpness from center to edges in the first pic, the improvement in the second pic, and the edge-to-edge sharpness in #3.
I'm guessing this is normal barrell distortion on a lens of this quality, pushed to the edge of its performance envelope like this? If I'm wrong and it's something else, could someone please tell me what? It takes great photos in more normal settings, and only displays this problem at full zoom and wide aperture. I know it's a middle of the road lens and I'm not expecting L performance or anything, just want to make sure I don't have a bad copy that needs replacing...
Thanks...
John_B
Gallery: 178 photos
Jan 02, 2007 06:26 |  #2
Stearmandriver,
If the lens is great in normal settings then just use it! The photos you posted of a flat subject at close distance is not what the lens is made for. It is also common for lenses to get sharper when they are stopped down as it showed in your photos (f/8 - f/11 is know as the sweet spot). Now go out and use the lens :)
click to see (external link)
Andy_T
Joined Jan 2003
Jan 02, 2007 10:14 |  #3
Stearmandriver,
just some thoughts ...
... it looks that you had the camera at an angle to the subject. This might explain why the pictures @ f/8 and f/16 are better than @ f/5.6 (larger DOF covers out-of-focus areas)
... at f/5.6, the lens is wide open. Plus, the 28-135 is not a lens especially noted for its sharpness. So it's not a big surprise for me that the f/5.6 image is not that sharp. The image @ f/8.0, OTOH, looks great to me.
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
Stearmandriver
Joined Jun 2005
Jan 02, 2007 17:11 |  #4
Thanks guys, that's what I thought. Just wanted to make sure I wasn't too ignorant to spot an actual problem while the lens would still be easy to replace. I'm pretty happy with it stopped down though, so it's all good!
1,583 views & 0 likes for this thread, 3 members have posted to it.
1255 guests, 177 members online
