MazerRakhm wrote in post #2518144
SATA is
supposedly hot swappable, or plug and play like USB (Meaning that you can connect and disconnect the drive whenever you want), but currently operating systems do not support this feature with it hence the lockup and non removal of the drive path from your system when you turn it off. Right now there is nothing you can really do to fix that issue.
Id have to say that statement is wrong. I am a computer IT, and a photog by hobby... Out of all the systems and servers I own, a HOW SWAP feature is a hardware specific feature. If write cashing is enables, and you uplug a drive, then good luck to you. You have data in casche / ram memory that hasnt been writtin to a drive and ur gona get corrupt data.
I have a $700 raid card which has a hot swap feature, and even then I have to go into my RAID Card console and "eject" the drive. Then yank it out... All hot swap means is that you dont have to power down the computer to take out a drive... Not that you can yank it out whenever you want to.
On standard motherboards, hot swapping isnt something thats a standard feature. This is why the system locks up. Your NOT supposed to remove the drive.
If the system was in a RAID config, and you took that drive offline like that, the computer would assume the drive has failed! And start a raid rebuild. The system still has to be told you want to yank that drive out. Or the system needs to be turned off and drive needs to be removed.
