Hi.
I thought I'd made up my mind on getting a Velbon Sherpa 750 R tripod and a Manfrotto 679B monopod, but before I make any purchases, can you recommend any other ones, or are these OK? The tripod should be able to go quite low (macro work) and to about ~160cm high. Also, it shouldn't be longer than 50-60cm retracted. Monopod should also be able to extend to ~160cm and be 50-60cm retracted.
I'm on a limited budget, so the two together shouldn't cost more than ~$150-200.
Thanks for all replies!
Brewster
