Thread started 02 Jan 2007 (Tuesday) 20:17
UK ROR equivalent?
tumblew33d
Jan 02, 2007 20:17 |  #1
Is there a UK 'Residual Oil Remover (external link)' equivalent for lens cleaning?
I normally blast with a rocket blower, breathe on the lens and wipe with clean cotton or microfibre, but there are a few oily smudges that I can't shift and I don't want to damage anything while trying.
I don't have to clean often, but I'd quite like a bottle to try as I've read good things about it.
MaxZoom
Jan 03, 2007 01:10 |  #2
OK I'm a skeptic!
From the MSDS I see ROR is a solution of 1% ammonia, Salt, Alcohol, Liquid Soap and Water and it also costs nearly $5 per ounce. Wow I missed a big business opportunity if only I could sell those ingredients at that price.
The advertising hype is awesome. This magic solution is going to 'clean' into the holes in the surface of my lens! I think I'd rather fill in any holes in my lens thank you.
If it were me I'd keep my expensive glass away from products containing ammonia and salt.
Just my two cents.
Max :rolleyes:
There's no such thing as a bad photo, just the wrong audience.
EQUIPMENT: Canon Powershot S3 IS, 2x Transcend 2GB x150 SD, 2x 4GB Class 4 Dane-Elec SDHC, LensMate 52mm Adapter Tube and lots of stuff to hang on it.
A couple of flashes and a couple of strobes. My other camera is a Sony DSC-P200.
tumblew33d
Jan 03, 2007 08:41 as a reply to  @ MaxZoom's post |  #3
What would you recommend instead?
phylet
Joined Feb 2006
Jan 03, 2007 19:43 |  #4
If im thinking corectly, which i probably am, but cant be taken to liability in doing so, a few% washing up soap in water is the perfect solution to remove grease from glass. However, it could be dificult to get it to all remove properly.
It would be worth finding out if you could put filters in the dishwasher i think, could get the very clean!
Canon EOS 1D MkII, Sigma 10-20 F4-5.6, Sigma 24-70 F2.8, Sigma 105mm Macro F2.8, Sigma Super 500 Flash
MaxZoom
Jan 04, 2007 11:04 |  #5
phylet wrote in post #2485457 (external link)
Washing up liquid is detergent, salt to thicken it up and coloring. That is some the kinder parts of the ROR liquid.
That is a joke is'nt it? A dishwasher would DESTROY anything optical. Have you ever seen what it does to wineglasses etc. Far too much salt and high pressure spraying and rattling about in the racks.:cry:
My suggestion. If you really believe you have a problem with "residual grease" then the dilute detergent is a viable option, I prefer to use J&J Infa-Care because we have it in the house and its extra-mild which I think means they did not throw a ton of salt into it like washing up liquid would have. Make sure you don't get the solution into a lens assembly use a dampened lens-friendly soft cloth. Let the item dry and then use an alcohol impregnated lens wipe to remove anything else. The isopropyl alcohol in the lens wipe will evaporate quickly and leave your optics sparkling, until you get messy with them again. I picked up a box of 50 pre-mosened Zeiss Lens Cloths in the optician section of Wal-Mart for about $3 they are individually wrapped like the towelettes you get on airplanes and are great out in the field when on a shoot. They even say they are safe for camera lenses and coated optics. :)
Max :rolleyes:
tumblew33d
Jan 04, 2007 11:43 as a reply to  @ MaxZoom's post |  #6
I'd better go and take my lenses out of the dishwasher.......
Sounds like the best thing to do is get some lens paper and some gentle lens cleaning solution. Or some Zeiss wipes as you suggested.
Thanks guys.
1,020 views & 0 likes for this thread, 3 members have posted to it.
UK ROR equivalent?
1742 guests, 128 members online
