Thread started 03 Jan 2007 (Wednesday) 07:40
UV/Skylight filters
dawnrogers
Jan 03, 2007 07:40 |  #1
Just wondered which you prefer? I ordered a Hoya digital skylight filter and they sent me the non digital one which is fine but they said they would send my the digital UV filter so I could try that and send the other one back if I prefered it 9good customer service) as far as I can tell from the sights there isn't a great deal of difference or am I missing something???
So which would you keep...UV or skylight??
Dawn
http://www.pivotalphot​ography.co.uk (external link)
My Blog (external link)
scottbergerphoto
Joined Jun 2003
Jan 03, 2007 07:49 |  #2
http://www.cs.mtu.edu …ide/filter/filt​er-UV.html (external link)
http://dpfwiw.com/filt​ers.htm#uv (external link)
Skylight filters are colored with some pink, so in addition to blocking UV rays, they add a warming effect. I use UV, which are not colored.
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
dawnrogers
Jan 03, 2007 07:57 |  #3
Thanks Scott.....thats what I thought but the guy at the shop was sort of indicating it didn't make much difference...!
Dawn
ScottE
Joined Oct 2004
Jan 03, 2007 20:28 |  #4
For digital cameras with auto white balance the slight red tint to a skylight filter does not make any difference. Your camera will correct for the tint of the filter. If you shoot RAW you can make more adjustments later in post processing.
Skylight filters were designed for shooting colour slide film at high elevations or other locations where light has a slight bluish tint. This was corrected by using a filter with a slight red tint.
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Jan 04, 2007 07:29 |  #5
dawnrogers wrote in post #2482279 (external link)
I think as long as it says SHMC then it should be the top end Hoya multicoating and it shouldn't matter if it says digital or not.
I use UV filters rather than skylight as skylight will slightly filter the blue end of the spectrum. Hoya might do protective filters also that do not cut UV but I suspect there is no real difference.
Macrophotography by LordV
822 views & 0 likes for this thread, 4 members have posted to it.
UV/Skylight filters
1742 guests, 128 members online
