Thread started 03 Jan 2007 (Wednesday) 21:12
s2 is
brantfordbandit
Jan 03, 2007 21:12 |  #1
I'm having trouble wi'll shutting in lower liht, say an indoor ice rink. i usually shoot in P but wanted to bump up the shutter speed but when i try and do it in manual and touch the button half way the image is almost black and my exposure reading is -2 and in red, why can't i shoot action shots?
canonguy
lostdoggy
King Duffus
Joined Aug 2004
Jan 03, 2007 21:27 |  #2
1st in sufficient lighting.
2nd maximum aperature too small.
Try Tv mode instead of M mode and bump up ISO to 400 and turn on IS.
brantfordbandit
Jan 03, 2007 21:33 |  #3
i've done that but i keep getting that -2 in red in the uper left hand corner where the exposure reading normally is
canonguy
lostdoggy
King Duffus
Joined Aug 2004
Jan 03, 2007 21:42 |  #4
That might mean that your SS is 2 stop too fast. You would need to lower it by 2 stop.
MaxZoom
Jan 04, 2007 05:49 as a reply to  @ lostdoggy's post |  #5
I think someone might be going the wrong way with shutter speed.
Firstly: If you need more light you need to be working at f/2.7 (wide) - f/3.5 (tele) as an aperture setting the lower this number the more light gets through your lens. The S2 & S3 go from f/2.7-f/8. f/2.7 gives the brightest image f/8 is darkest.
Secondly: Yes select the highest ISO speed possible on an S2 that is 400ASA and on an S3 that is 800ASA. Yes you will get noise but it is more improtant to start getting pictures, noise is easily removed in PP.
Thirdly select the slowest shutter speed you can be steady at. Your ice scaters may be moving too fast for 1/25 or 1/50 of a second which will display as 25 or 50 on the S2 so you might have to go to 100 - 125 - etc but you keep getting darker!
The -2 in red indicates you are 2 or more EV too dark with your exposure setting. Do each of the above until you come to 0 and then adjust to your taste.
Max :rolleyes:
There's no such thing as a bad photo, just the wrong audience.
EQUIPMENT: Canon Powershot S3 IS, 2x Transcend 2GB x150 SD, 2x 4GB Class 4 Dane-Elec SDHC, LensMate 52mm Adapter Tube and lots of stuff to hang on it.
A couple of flashes and a couple of strobes. My other camera is a Sony DSC-P200.
Gerald-NC
Jan 04, 2007 13:20 |  #6
slight correction, ^^ meant to say 2.7 gives you the brightest instead of the 7.8 he typed :D
The faster the shutter, the less light you let in.
The larger the aperture setting the less light you let in.
The lower the ISO setting, the less light you let in.
So correct these things and see what happens.
C&C Is Always Welcomed and Encouraged!
500px (external link)
Canon EOS Rebel XSi / 450D Kit EF-S IS 18-55mm Lens, Shorty 40mm, EF 55-250mm STM
lostdoggy
King Duffus
Joined Aug 2004
Jan 04, 2007 19:00 |  #7
Ok if we want to be technical here:
Maximum aperature is the largest posible opening allow by the lens and for zoom lenses, that would be for the given focal length represent by the largest number (in fraction, as in f/2.8 or f 1/2.8 where f=focal length of the lens). So, if said that the maximum aperature is too small then what is meant is that the lens at its maximum aperature can not provide sufficient light at the given shutter speed to properly expose the film/sensor.
It is also not correct to assume that 1/125" is sufficient shutter speed to offset camera shake since the S2/3 IS's zoom is capable of 432mm(35mm equivalent) with opticle zoom only. Given that the camera has IS and it is capable of offsetting camera shake by 2 to 3 stops a more usable speed would be 1/250" although improved camera handling may allow you to shoot reasonably clear images at 1/125" at full zoom (opticle only)
brantfordbandit
Jan 04, 2007 19:58 |  #8
the reason i wanted to bump up the shutter speed was also because the subjects where blurry
canonguy
MaxZoom
Jan 05, 2007 00:55 |  #9
brantfordbandit wrote in post #2490442 (external link)
If you are already at ISO400 and f/2.8 then a good flash is the only answer with this camera. If you had a dSLR you could go for a faster lens but then you have only one or two f/stops at most unless you can work with a very fast primary lens. If you are getting too much action blur at f2.8 & 800ASA and 1/125 then going to f1.4 & 1600ASA 1/1000 with such a dSLR might get what you want but you will have spent an awful lot of money and have reduced the problem to 1/16 of what you have now which is probably enough.
lostdoggy wrote:
It is also not correct to assume that 1/125" is sufficient shutter speed to offset camera shake...
I agree. I do not believe there is any 'magic speed' at which there is no camera shake. Each time you halve the shutter time you halve the effect. I've known some who get bad shake at 1/250 @ 50mm equivalent focal length, equally on a very good day and a lot of care I've managed 1/2 @ 50mm. I rarely have very good days so nearly always have a tripod or a monopod to hand.
In this case the subject moving on the ice rink is going to be the problem which no amount of good handling is going to cure at the camera end.
Max :rolleyes:
1,303 views & 0 likes for this thread, 4 members have posted to it.
s2 is
2187 guests, 128 members online
