Thread started 04 Jan 2007 (Thursday) 13:38
SD400 batterie issue
julienf
Jan 04, 2007 13:38 |  #1
Hi all,
i'm facing problem loading my SD400 camera batteries: the little light saying that the battery is loading and then full stay off whatever i do. The batterie stay empty.
I would like to know if one get an idea to help me with fixing this batterie loader !
Thanks !
gjl711
Jan 04, 2007 13:46 |  #2
How old is the battery?
But it is easy to check the charger. Look at the voltage coming from the charger. It should be 4.2 volts for that battery I believe. If the voltage is much below 4, then the battery will not charge. If the voltage is 4.2, next measure the battery. It should read very close to 3.8. If it is not and the charger will not charge, it is time to replace the battery.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
julienf
Jan 04, 2007 13:47 |  #3
good idea... have to find something to check the voltage then
ps: i checked 2 batteries: one i bought 4 months ago and a older one
gjl711
Jan 04, 2007 14:04 |  #4
julienf wrote in post #2488873 (external link)
And both show the same problem? If so odds are that the charger is not working. It would be quite coincidental for two batteries to fail at the same time.
::Gear::
julienf
Jan 04, 2007 14:11 |  #5
you are probably right, as i didn't find my tool to measure the voltage (don't know how to say in english), i used my tong on the charger and the batteries: nothing for the charger (luckily for me !).
Conclusion: i am going to buy a new charger (40$ in France). urghh !
Thanks a thousand time for your help ! (i tried to find a solution on french forums for more than a week, and when i come here i get helps in less than 20 minutes !!!)
gjl711
Jan 04, 2007 14:49 |  #6
Good luck, hope that solves the problem.
::Gear::
1,427 views & 0 likes for this thread, 2 members have posted to it.
2187 guests, 128 members online
