Thread started 04 Jan 2007 (Thursday) 19:31
First Basketball Game.
cdifoto
Don't get pissy with me
Jan 04, 2007 19:31 |  #1
Every shot except the wide and under-basket ones are on the 30D 85mm f/2.0 1/400th ISO3200 with the 85mm f/1.8. The others are with the 24-70 f/2.8L on the 10D at 1/200th f/2.8 and ISO3200. The only one cropped was the last because my horizon was terrible.. Others are as-framed.
warrior6901
Joined Nov 2005
Jan 04, 2007 21:50 |  #2
Not too bad for action, but these are always tricky with arms in front of the face, etc. We all know how horrible the lighting is, but would suggest continue working on exposure and WB.
"The bitterness of poor quality is remembered long after the sweetness of low price is forgotten."
mr.vair
Jan 04, 2007 21:55 |  #3
I like the third one the best. It really takes a ball and a face to make most sports shots. jump shots without a face are less interesting to folks looking at them. beware of distracting parts of your images. example in #1, the arm pretty much makes it a discard most of the time. there again, my jugdement is from reporting (shooting) sports for newspapers, your mileage may vary.
cdifoto
Jan 04, 2007 21:58 |  #4
warrior6901 wrote in post #2490949 (external link)
WB I was lazy since I just got home from the game right before posting. Didn't even touch it yet - it's really not that far off TBH. Most of these girls are as pale as it gets. Exposures though are spot on via handheld light meter. I do agree about the arms. They get/got me almost the entire time but I have some less-peak action shots that have faces.
cdifoto
Jan 04, 2007 21:59 |  #5
mr.vair wrote in post #2490978 (external link)
I'd normally trash the first too because of the ref's arm...but I like her drive on that shot. It's not even 100% sharp anyway.
Thanks for commenting, both.
sageone
Jan 04, 2007 22:25 |  #6
bball is harder than some think to shoot. Lots of movement, tough angles, etc. I think that 85 prime is a great lens for the job. I also use my 70-200 just in case when I need to get close in at half court. These shots are pretty good, a tad soft, but good.
Don Martelli
www.donmartelli.com (external link)
cdifoto
Jan 04, 2007 22:39 |  #7
sageone wrote in post #2491136 (external link)
There wasn't nearly enough light for my 70-200. I could get 1/200th with it and that's it. I only used the 24-70 for a select few shots because it just wasn't fast enough. The noise is probably what's making them look soft. I also went light on the sharpening because of so much of it. I'm batching them through NeatImage to see if sharpening after cleaning helps.
I wish I had a wide prime. I'm putting that 28mm f/1.8 back on the wishlist...might have to settle for it until I can swing the 35L.
cdifoto
Jan 05, 2007 00:17 |  #8
These next few aren't nearly as exciting but they've been cleaned up and sharpened a little more aggressively. Not sure if that worked or not. I adjusted the WB but I think I flubbed it. Don't really care though to be honest.
Photodawg1
Jan 05, 2007 03:35 |  #9
I think great first attempt. Although a shame about the arm, I like the first one best too. Amazing how much sharper/brighter they look once you had a chance to process. I am impressed at how good you filled the frame with the players. Need to gets me that 85! Look forward to seeing more of your hoop shots.
Linda
______________
http://www.lindasiadys​.com (external link)
cdifoto
Jan 05, 2007 03:51 |  #10
Thanks Linda. Overall I'm happy with these. They're a lot better than my first attempts at other indoor sports. I know I'll improve the more I shoot.
Here's one just for the sake of it:
Photodawg1
Jan 05, 2007 03:56 |  #11
Shoot! I changed my mind...that last one is my favorite! That would make a great poster! Although the left lower corner and ceiling seems to detract the eye somewhat. Not nitpicking cuz I love it... if you could blur that window out some...:)
______________
cdifoto
Jan 05, 2007 04:22 |  #12
PS isn't my forte, but how does this look?
Photodawg1
Jan 05, 2007 04:26 |  #13
Exquisite!
______________
grego
Jan 05, 2007 04:35 |  #14
I'd take out #1, 2, 3, 4
Then crop tighter on the last two in post #8.
In the future, just use incandescent wb. I'm betting the Kelvin level is around 3500k.
Overall, good job for first time.
Go UCLA (external link)!! |Gear|http://gregburmann.com (external link)SportsShooter (external link)|Flickr (external link)|
cdifoto
Jan 05, 2007 04:41 |  #15
grego wrote in post #2492174 (external link)
It's set to 3500K now.
2,834 views & 0 likes for this thread, 8 members have posted to it.
2432 guests, 103 members online
