Thread started 05 Jan 2007 (Friday) 15:50
-=Calling All SIGMA Tele Lens users!=- Canon T-con Compatibility Chart. PLEASE HELP
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jan 05, 2007 15:50 |  #1
We are putting together more info for the -=T-Con FAQ=-
We want to know the complete list of SIGMA lenses that will work with Canon brand T-CONs and which will not
Below is a complete list of all SIGMA lenses designed to work with Sigma's own T-Cons, as well as there AF Functionality with Canon DSLRs when a T-CON is used.
Only these listed are likely to be able to work with a Canon T-con do to reasons of physcial size, however we know that some do not.
The size of the Sigma T-Con "protrusion" is slightly smaller in diameter, so some lenses reportedly, like the 150mm Macro and 70-200mm, do not Fit the Canon T-cons larger diameter.
EX lens Compatibility Sigma T-Cons -- 30D/5D/350D* -- 1D series*
- Exclusive lenses - - --------------- 1.4X-- 2X ------ 1.4X -- 2X
APO 120-300mm F2.8 EX IF HSM -------------- AF --- AF ------- AF --- AF
APO 300-800mm F5.6 EX IF HSM -------------- MF --- MF ------- MF* --- MF
APO 70-200mm F2.8 EX HSM --------------- AF --- AF ------- AF --- AF
APO 300mm F2.8 EX HSM ---------------AF --- AF ------- AF --- AF
- Usable lenses - -
APO 500mm F4.5 EX HSM --------------- MF --- MF ------- MF* --- MF
APO 800mm F5.6 EX HSM --------------- MF --- MF ------- ??* --- MF
*1 APO MACRO 150mm f2.8 EX HSM ---------- AF/MF MF ------ AF/MF - ??*
*1 APO MACRO 180mm F3.5 EX IF HSM ------ AF/MF MF ------ AF/MF - ??*
*2 APO 50-500mm F4-6.3 EX RF HSM ---------MF --- MF ------- MF --- MF
APO 100-300mm F4 EX IF HSM --------------- AF --- MF ------- AF --- AF
APO 80-400mm f4.5-5.6 EX OS --------------- MF --- MF ------- AF --- MF
APO 135-400mm f4.5-5.6 --------------- MF ---- MF ------ MF --- MF
Below are the SIGMA lenses that I know FIRST HAND work with Canon TC's
Please add your info and any proof you might have (photos of it assembled would be nice, but we will tend to trust you too ;) )
What we have thus far;
EX lens Compatibility w/ Canon T-Con 30D/5D/350D* -- 1D series*
- Compatible lenses - - --------------- 1.4X-- 2X ------ 1.4X -- 2X
CONFIRMED DOES NOT FIT
Macro 180mm f/3.5 EX IF HSM --------- EF MKII Versions do not fit.
APO 70-200mm f2.8 EX HSM ------------EF MkII Versions do not fit. EF MkI 1.4x Fits with full AF
50-500mm EX (non IS) ---------------EF MkII Versions do not fit well. (would like further info)
CDS' HOT LINKS
poah
Jan 05, 2007 16:04 |  #2
70-200 works with the mk1 TC but not the mk2 - from my own experience
Free printer profiles PM me for info
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jan 08, 2007 12:02 |  #3
Thanks for that Poah.. wow, MkI Vs. MkII.. this is actually a huge help and it explains a bit as we get conflicting info re: some fo these combos. It never occurred to me that the MkI was physically different diameter.
C'mon folks, I KNOW there are a lot more Sigma owners out there with info...
Where are you all hiding?
CDS' HOT LINKS
DavidEB
Jan 08, 2007 13:36 |  #4
and I can tell you firsthand that the canon 1.4x tc mark II does NOT fit the sigma 70-200 f2.8 EX HSM non-DG version.
David
my stuff - [URL="http://www.pbase​.com/davideb"]my gallery - [URL="http://photograp​hy-on-the.net/forum/showpost​.php?p=3928125&postcou​nt=1"]go Rats!
Simon ­ Harrison
"Bag Snapper"
Jan 11, 2007 16:36 |  #5
I use the Canon 1.4 mk II TC without any issue with my Sigma 120-300 f2.8 EX DG HSM.
Cheers,
Simon.
Simon
http://www.flickr.com/​photos/srhmoto/ (external link)
Miyagi-san
Jan 23, 2007 16:34 |  #6
I was going to post this in "lenses" but figured it would be better suited here. Sorry if I'm wrong! :)
I just got my Sigma 150mm2.8 and Sigma 2X convertor....
I could have sworn I read on the board here that you can use the 2 together and retain AF....but it is definitely not working when I mate the combo up to my 300D....the LCD displays max f5.6 though....
Not a big deal really, as this is a lens that will see a lot of MF anyway :D But just making absolutely sure that it indeed should not be working?
Thank you!
".....Nice camera! .....How many times zoom?!?"
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jan 31, 2007 07:50 |  #7
I've input the the info we've gathered thus far,...
Where's all the Bigma owners?
CDS' HOT LINKS
JuZ
Joined Jun 2005
Feb 07, 2007 01:42 |  #8
I have a 1D MkII and use the Sigma 500mm f/4.5, it's definately manual focus with the 1.4x Canon TC, it does AF with the cheapy Tamron one I have though :)
JuZ ;)
canonloader
Gallery: 6 photos
Mar 21, 2007 16:10 |  #9
My 50-500mm Sigma/Bigma arrived today. The Canon 1.4x TC II and the 2x TC II do NOT fit inside the small end of the Bigma. They go in part way, then it feels like there is a rubber gasket it hit's against. There is no gasket, but that's what it feels like if you've ever done any auto repair. In other words, it doesn't feel like metal to metal. I did have the lens zoomed out to 200mm or so and the Lock set. There is room at the back of the inner zoom part of the lens for the extension part on the Canon TC, but the diameter seems to be too small.
Kenko tubes for the EF mount DO work with this lens though and retain AF on the 30D.
Mitch- ____...^.^...____
august23
Sensitive + Shopoholic = chick?
Mar 21, 2007 16:29 |  #10
Removed as a sticky? We're gonna let this one fall huh? :p
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Mar 22, 2007 22:23 |  #11
It's linked in the T_Con FAQ.. easy to find still. Don't need two T-Con stickies. Besides, it didn't seem to go over well, it was stuck for months with just the five helpful posts.
thanks for the info Mitch.
We still need info on the 100-300mm f/4, and the two big Macros!
CDS' HOT LINKS
nandy
Apr 20, 2007 15:18 |  #12
I have a sigma APO 70-200 HSM EX and a works well with my canon 20D,
I just recently purchase the Sigma APO 2X Tele converter and I'm getting ERROR 99
I tried to clean the sensors and do exactly what the directions says and I'm still getting the same ERROR also makes a sound before I turn the camera on.... can some Help me
thank
Nandy
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Aug 18, 2010 11:05 |  #13
Bump!
I'm just going to try this again.. lots of new SIGMA lenses out now, and still wishy washy info I'd like to get confirmed.
Help a forum out! :)
In particuler we want to know if the Canon MkII or MkI T-Cons fit and fucntion with
150-500mm BIGMOS
50-500 BIGMA
50-500 BIGMA II OS,
Newer 70-200mm F2.8 EX DG APOMacro HSM II
Newest 70-200mm F2.8 EX DG OS HSM
100-300mm f/4 (we think they do fit, but need first hand confirmation)
120-400mm OS
The 150mm Macro
CDS' HOT LINKS
DreDaze
Gallery: 49 photos
Aug 18, 2010 11:51 |  #14
well it's not really what you asked for...but i can tell you the sigma 150-500mm physically fits with the kenko 1.4X, and you can tape the pins to retain some form of AF...
i only mention this because i think it'd help if the TC sticky had some mention of the kenko brands since they are recommended quite a bit, but aren't really discussed in that thread
Andre or Dre
gear list
Instagram (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Aug 19, 2010 11:13 |  #15
As for compatibility, the Kenko's "fit" every EF mount lens made, so they don't need a chart..
But yes it would be nice to clean up and orgnaize the discussion of the 3rd party T-Cons better.
CDS' HOT LINKS
12,416 views & 0 likes for this thread, 10 members have posted to it.
1463 guests, 137 members online
