Thread started 08 Jan 2007 (Monday) 19:44
CF Cards - Full or Not?
caljimw
Jan 08, 2007 19:44 |  #1
In High School I used a 4"X5" Speed Graphic. Sheet film holders had a slide which was removed before making an image. One side of the slide tab was black/ the other white. Unexposed sheets were identified by the white side being "out". After exposure, the slide was reinserted with the black side "out." Remembering this, I now put a small letter "C" on one end of theCF cards, and a small Letter "C" on one end of the plastic CF case. After one is filled, it is returned to the plastic holder, with the "C" on the opposite end of the case, which indicates it is full. After offloading the images, and clearing the CF card, it is returned to the case, with both C's at the same end.
The same thing works with batteries and the contact protector case.
1D Mk II N, 7d, 100-400 IS "L", 70-200 f2.8 L, Sigma 10-20, 50mm f1.8, 24-70 f2.8L, Lensbaby, 430ex, etc.
GALLERY: www.pbase.com/caljimw (external link)
"Write me as one who loves his fellow man." Leigh Hunt
Echo63
Jan 08, 2007 22:23 |  #2
when i bought my second Ultra II 2gb the other day i thought about this too as i now have two cards that are the same
so i printed up some little red and green flags with "empty" on the green side and "full, download before reusing" on the red side, these are stuck to the back of the CF card case and hinged with tape then when you put a full card back in you flip it so the red side faces out and you know your card is full
they are stuck to the back of the CF card case (where the holder has tabs that "hold" your card)
my little tags also have my name and phone # on them (it was cloned out of these shots)
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
Savagebasher
Jan 08, 2007 23:48 |  #3
for my cards which are the same, I wrote I and II on the back of them. I just use them in order then.
BradT0517
I almost caught fire
Jan 08, 2007 23:54 |  #4
Echo and savage you both have some really good ideas now if only I had more cards so I could do something like that.
My Website (external link)
Rumjungle
Jan 09, 2007 01:00 |  #5
Good ideas. For me, empties go in a holder and the full ones get thrown in a separate pouch.
Gear
Savagebasher
Jan 09, 2007 01:01 |  #6
Also, I tend to work my way up with cards, starting with the smaller ones, since I'm normally taking pictures before the main event, and save the large cards for when I'll be shooting bursts and for longer periods of time.
Echo63
Jan 09, 2007 01:19 |  #7
Savagebasher wrote in post #2511896 (external link)
and i normally do the opposite, start with my 2x 2gb, then my 1gb, then my 256mb, although if i use the 256mb i also switch to jpg
i also have a 8mb card, it just fits the 350d firmware upgrade on it (1.0.3 i think)
Woolburr
Rest in peace old friend.
Gallery: 115 photos
Jan 09, 2007 03:19 |  #8
I carry my media cards in these cases....Blank, formatted cards are stored face up, full cards are face down. Owner contact info and card number is also found on each card.
Halliday
Jan 09, 2007 03:56 |  #9
Fresh cards in the left pocket, used cards in the right pocket, just like my film days. When I use a card wallet, fresh: face up, used: face down.
lanceshuey.com (external link)
"Like a mechanic who forgets to wipe his hands on a shop rag and then goes home, hugs his wife, and gets a grease stain on her favorite sweater — love touches you, and marks you forever."
Salleke
Jan 09, 2007 04:19 |  #10
Halliday wrote in post #2512194 (external link)
Fresh cards I left in the gearbag and in the holders and full cards I put in a
special pocket in the jacket I wear. Never had a problem untill now.
Good luck and don't mess things up ... ;)
Jon
Joined Jun 2004
Jan 09, 2007 06:23 |  #11
Cards are in wallets, and like others using 'em face-up's empty and face-down's full.
Jon
Cocker Spaniels
SkipD
Joined Dec 2002
Jan 09, 2007 06:26 |  #12
Tamrac has a nice little memory card case that has red flags that you can use for the purpose. If the flag is inside the pouch, the card is fresh. Pull the flag outside, and it shows the card being used already.
Here's a link to the case at B&H: Tamrac MXS5368 (S.A.S.) Memory & Battery Management Wallet 4 (external link)
I keep four memory cards in my case, and the space in the middle is perfect for two extra batteries for my 20D.
Skip Douglas
1,844 views & 0 likes for this thread, 10 members have posted to it.
2261 guests, 125 members online
