Thread started 10 Jan 2007 (Wednesday) 16:45
Have to brag a little bit
ib2loud
Jan 10, 2007 16:45 |  #1
I recently got some cheapo rechargeable batteries from wal-mart, I can't think of the brand name, if they even have one.
anyway, I shoot cars for dealerships and in the last two days I've taken over 1200 photos with my S3 IS on the same set of batteries, without removing them or recharging them, and they still don't show to be low
I was really impressed with this, keeping in mind I only use the small viewfinder and the flash was used on maybe 30 shots, but still I think that's good, hopefully they'll keep going this well.
KoiBoy
Jan 10, 2007 23:18 |  #2
you should take a picture of the battery your using so we all can see what it look like :) i just got some rechargeable 2500 mAH batteries, just starting charing them and will see how they last, i don't buy anything beyond 2500 mAH.
--\\\///-- Canon Powershot S3 IS --\\\///--
;-)a8-);-)a8-);-)a8-);-)a8-);-)a8-);-)a8-);-)a8-);-)a8-);-)a8-);-)a:cool:
Dante ­ King
"Cream of Corn" BurgerMeister
Joined Jan 2005
Jan 10, 2007 23:31 |  #3
rechargeables dont typically show low, they just show the i'm almost out sign at the worst possible time.
Dante
I am not an Lcoholic. Lcoholics go to meetings!
MaxZoom
Jan 11, 2007 01:20 |  #4
KoiBoy wrote in post #2522277 (external link)
What is the thinking here? Why not the bigger-the-better?
Max :rolleyes:
There's no such thing as a bad photo, just the wrong audience.
EQUIPMENT: Canon Powershot S3 IS, 2x Transcend 2GB x150 SD, 2x 4GB Class 4 Dane-Elec SDHC, LensMate 52mm Adapter Tube and lots of stuff to hang on it.
A couple of flashes and a couple of strobes. My other camera is a Sony DSC-P200.
lostdoggy
King Duffus
Joined Aug 2004
Jan 11, 2007 01:37 |  #5
Bigger is better!!!
If the battery is blue/green (teal) then they are Digital Concept by Sakar. I use to use them but find they don't have many cycle in them before dieing I got them for about $3.99 for 4. Now I use Ultra Last silver color 2600mAH and I get them for $4.99 for 4. I usually carry at least 2 xtra set cause ext Flashes eats batteries like there is no tomorrow.
MaxZoom
Jan 11, 2007 02:00 |  #6
lostdoggy wrote in post #2522590 (external link)
Bigger is better!!!
Maybe I'm out of sync?
I use Energizer Ni-Mh marketed by the Everready Battery Company Inc but some are made in China (shiny silver) and some in Japan (matt silver). The printing is normal energizer Black - White and 2 shades of green. Does what you say apply to these batteries?
I've found some flashes do not like Ni-Mh they cant cope with the lower voltage, nothing to do with the mAh capacity of the battery.
Max :rolleyes:
KoiBoy
Jan 11, 2007 11:50 as a reply to  @ MaxZoom's post |  #7
i actually wanted to get 2700Mah batteries, but after carefully researching... (i always thought bigger is better, but i guess not always true).. here is the warning from a battery seller, they don't sell anything above 2500Mah and won't.
"Warning: Please don't try 2600mAh or above AA NiMH battery, you are risky on either unreal label or short cycle life and shelf life."
this notice came from a seller that i buy my batteries from and the batteries and done very well for me the past yr. HERE (external link)
i check in costco and other stores for brand name batteries and found they only had 2500Mah on them, the ones i found with 2700Mah were only on-line. but to be on the safe side i'm just sticking with 2500Mah.. it gets pretty hot when charing already with 2500Mah using standard charing time of about 3 hrs for 4x 2500Mah batteries, can't image how hot it would be with 2700Mah.
here is a article taking about which is the best 2700Mah.. and Sanyo seems to be the best and only choice for 2700Mah.
link HERE (external link).. :)
MaxZoom
Jan 12, 2007 02:05 as a reply to  @ KoiBoy's post |  #8
Thanks KoiBoy, I had a look at the links you provided.
I have Brand-X NiMh batteries in work from 1700 to 2500mAh and frankly found them to be rubbish. They were nearly always flat after 2days to a week.:(
All my home NiMhs were bought in Sams Club, they won't let me into CostCo:(
At home I always use Energizers 2500mAh (and I think I have some 2750's too even if Energizer don't seem to know they do them) and they all go like those pink bunnies! (THINKS: Is this the first/only time advertising was actually meaningful???):shock:
From the Energizer web site i got this quote "The higher the capacity, the longer the battery will last between charges." which seems to go against what you are finding.
A bigger capacity battery should not get hotter when charged, they will just take longer to charge. If I was on e-Bay and only sold batteries up to 2600mAh I'd advise my customers not to try bigger ones too:lol:
Could you please tell me what HR labelled batteries mean? The thread you linked to mentions them but does not explain.
Max :rolleyes:
KoiBoy
Jan 12, 2007 12:10 as a reply to  @ MaxZoom's post |  #9
MaxZoom,
sorry i have no clue what HR label means.. i'm not that technically skilled :lol: but i did find another link about batteries..., and has for the heat.. basically after a good 3 hours of charging (2500mAh) it gets a bit 'warm' but after a few mints. after charging it cools to touch.
i was thinking the same.. higher capacity the better, but looks like the only one that can be trusted in the 2700mAH range and higher is SANYO batteries. i would trust the others.
Costco used to carry Sanyo batteries with charger (i got a few 2500mAH, works great haven't failed on me over 1yr ago.) now Costco only carries Duracell rechargeable $29 +/- (i think only 2400mAH, unless i'm wrong) and Sony w/ charger with refresh function $39 +/- (2500mAH)
here is an article on batteries and chargers (external link)...
wish i can help more. but i'm just going to stick with 2500mAH. Sanyo and the brand i recently got.
MaxZoom
Jan 12, 2007 17:18 |  #10
KoiBoy wrote in post #2529625 (external link)
No prob, just thought I'd ask - thanks.
I followed your link to another link (external link)comparing NiMh batteries it is a little bit out of date but interesting. According to them The Energizer batteries I've been using "by accident" seem to be top of their heap by a very small margin. Looks like going for a major brand like Sanyo or Energizer is the best way to avoid problem batteries.
Thanks for the extra info.8)
Max :rolleyes:
1,361 views & 0 likes for this thread, 5 members have posted to it.
2200 guests, 127 members online
