ok Ive wondered about this.Would it be wise to get a tripod head with a lower weight cap. than the actual tripod legs?Example a Bogen 484RC2 is at 8.80lbs where the 3021 Pro tripod has a capacity set at 13.20lbs.
thekid24 pro-zack-lee 8,547 posts Likes: 7 Joined Oct 2006 Location: Oklahoma City,OK More info | Jan 10, 2007 19:32 | #1 ok Ive wondered about this.Would it be wise to get a tripod head with a lower weight cap. than the actual tripod legs?Example a Bogen 484RC2 is at 8.80lbs where the 3021 Pro tripod has a capacity set at 13.20lbs.
nodoubt Senior Member 452 posts Joined Jan 2006 More info | Jan 10, 2007 19:38 | #2 thekid24 wrote in post #2521115 ok Ive wondered about this.Would it be wise to get a tripod head with a lower weight cap. than the actual tripod legs?Example a Bogen 484RC2 is at 8.80lbs where the 3021 Pro tripod has a capacity set at 13.20lbs. .......i wouldnt.....i have those legs and the 486 head and im not happy with the head....looking to get something bigger as we speak.... 40d....
thekid24 THREAD STARTER pro-zack-lee 8,547 posts Likes: 7 Joined Oct 2006 Location: Oklahoma City,OK More info | Jan 10, 2007 19:45 | #3 nodoubt wrote in post #2521141 .......i wouldnt.....i have those legs and the 486 head and im not happy with the head....looking to get something bigger as we speak.... Ah good info.Some of the time people give their advice/opinion without actually having the items,at least you said you have both and are not happy with the setup.Was the problem due to it being a ball head or just the differences in weight capacity?Are you looking for a pan and tilt head or still going for the ball heads?
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Jan 10, 2007 19:47 | #4 thekid24 wrote in post #2521115 ok Ive wondered about this.Would it be wise to get a tripod head with a lower weight cap. than the actual tripod legs?Example a Bogen 484RC2 is at 8.80lbs where the 3021 Pro tripod has a capacity set at 13.20lbs. The answer to your question really should be based on what you intend to support with the tripod. Skip Douglas
thekid24 THREAD STARTER pro-zack-lee 8,547 posts Likes: 7 Joined Oct 2006 Location: Oklahoma City,OK More info | Jan 10, 2007 19:52 | #5 SkipD wrote in post #2521187 The answer to your question really should be based on what you intend to support with the tripod. For larger cameras with larger lenses such as the 70-200 f/2.8L, the 484RC2 is way too small. The 486RC2 is even lacking a little ability to eliminate creep. The 488RC2, on the other hand, works very well with lenses such as this one. As of now I do not own a large lens such as the 70-200L but in time I will and would rather buy now and once than have to keep buying.Also I plan on having a Mk II N in the future as well.So lets say I have both Mk II N and the L lens,would the 488RC2 with the 3021Pro be sturdy enough?
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Jan 10, 2007 20:31 | #6 thekid24 wrote in post #2521220 As of now I do not own a large lens such as the 70-200L but in time I will and would rather buy now and once than have to keep buying.Also I plan on having a Mk II N in the future as well.So lets say I have both Mk II N and the L lens,would the 488RC2 with the 3021Pro be sturdy enough? That's the combination I use all the time. It has always done everything I have wanted it to - and quite well at that. You would not be disappointed even with the high-end gear. Skip Douglas
kram obvious its pointless 2,612 posts Likes: 3 Joined Feb 2005 More info | Jan 11, 2007 04:24 | #7 You will never want to risk gear that's heavier than the head/leg capacity. To that extent, you will only be carrying around dead weight. Canon 7D , Canon 6D, 100-400 L, 24-105 F4 L, 50 F1.4, Tokina 12-24 F4, Kenko Teleplus Pro DG 1.4X Extender
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Jan 11, 2007 06:28 | #8 The amount of weight that a tripod or head is rated for can be very deceiving. I wonder if all manufacturers use the same method for arriving at those numbers. My suspicion is that the better tripod/head manufacturers tend to rate their equipment more for what can be held steady (without creep) than the manufacturers of cheap equipment. Skip Douglas
thekid24 THREAD STARTER pro-zack-lee 8,547 posts Likes: 7 Joined Oct 2006 Location: Oklahoma City,OK More info | Jan 11, 2007 13:42 | #9 As of right now I figure the 484RC2 would be enough to hold my XT but Ive read an article that was linked somewhere here on the forums about a guy that wasted money on continually buying tripods.And Ive heard on these threads as well about buy once,meaning no need to buy a cheap tripod because it is cheap.Spend the extra money and buy your 'last tripod' first.Which is usually what I do in any circumstance.Not every time because I did buy a 55 cent tripod off of ebay but at the time it was for my S3 which was not heavy at all.Now that Ive gotten my XT and plan on having bigger lenses and a heavier body(Mk IIN),a more rigid and sturdy tripod is amoung the top of my 'need-to-have' list.Thanks for all the help that was provided here.
nodoubt Senior Member 452 posts Joined Jan 2006 More info | Jan 11, 2007 17:25 | #10 thekid24 wrote in post #2521174 Ah good info.Some of the time people give their advice/opinion without actually having the items,at least you said you have both and are not happy with the setup.Was the problem due to it being a ball head or just the differences in weight capacity?Are you looking for a pan and tilt head or still going for the ball heads? ....it just didnt seem sturdy enough.....im still looking at ballheads.... 40d....
StealthLude Goldmember 3,680 posts Joined Dec 2005 More info | Jan 11, 2007 17:30 | #11 The 3021B Pro and the 488 head is a wonderful combo. Thats what I am using right now, and It seems to match up perfect. [[Gear List]]
| Latest registered member was a spammer, and banned as such! 2253 guests, 124 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
