Thread started 12 Jan 2007 (Friday) 10:15
Monopods -questions and purchasing advice
dsmgirl
Jan 12, 2007 10:15 |  #1
I used to laugh at monopods. Then I got a Bigma. Now I'm looking at purchasing one, but, I'm not sure what features I need/want...
Uses:
Basically, it just needs to hold my Bigma up while I'm shooting at the racetrack (cars) mostly, but I may use it for nature photography as well. If I find it works well, there's a possibility I may use it with my other lenses as well for general walk-around slow SS shots, etc. We'll have to see how it actually does at stabilizing the camera first, though. ;)
About Me:
My budget is around $100. I can't see spending any more for a stick with a camera attachment on it. I'm not one of those people that must have the best brand, model, or features -I just want something that works.
Features I like: clip locks rather than twist and anything that helps speed up setup and breakdown -I tend to move around the track alot (I move too much w/ nature shots too), so I'm constantly packing up/unpacking my stuff. Anything that helps with that -fewer sections, quick release, etc will be considered a plus.
Selection Questions:
I've searched through the archives and found that Bogen / Manfrotto is recommended most, but others have had good experiences with Gitzo and a few others. I'll lean towards those based on several discussions I've read. The Bogen / Manfrotto 680B (3249B) is actually sitting in a cart on B&H right now ;) (I'm willing to change that, though.)
The real question comes down to the head. First, do I need one? -If the monopod will really only be used to support the camera, maybe not? But since I've never used a monopod before, I don't know what features I'd use...
One thing that bugs me about my current $25 tripod is the fact that I'm stuck with the horizontal (landscape) orientation. I'd love the ability to turn the camera 90* to portrait. Now, the Bigma has the ability to change the orientation on the lens support, which really seems like a better way to go IMO -rather than having the head support all that weight off to one side, but I've never used a tilt or ball head tripod or monopod, so I'd appreciate any feedback on this that you may have.
Another question I have is whether the monopod is useful for panned shots? I do a lot of panned shots and I have a feeling that even with a head that will rotate ("pan"), I'll probably still opt to pick the camera up to pan because the pan motion is more of an arc than a circular rotation. -Is this what you guys have found? Is a "pan" option non a monopod head useful at all?
If it turns out I want a head, which one? Ball? Tilt? The 484 Mini Ball Head from Bogen / Manfrotto says it supports up to 8.8lbs. My 30D + the Bigma is about 7 or 8lbs I think. That's a little closer to the "max weight" than I'd like, but it sounds like it'd work. The tilt heads they offer only support 5 - 6lbs, so that may answer the question right there... Unless you'd recommend another head -maybe just with quick release???
I know that's a lot of info/questions, but I'm hoping you guys can help me make a good decision here. So, please give me any advice you can on this monopod stuff 'cause it's all very new to me. -Perhaps I don't even know enough to ask the right questions?
Thanks in advance,
-Erica
My Flickr photostream (external link)
My website: http://muddyboots.org (external link)
René ­ Damkot
Jan 12, 2007 10:30 |  #2
You won't need a ballhead for shooting sports IMO. You will use the lens collar anyways.
Just attach a quick release clamp to the monopod.
The manfrottos are fine. I have a 449. Gitzo has twist locks (which I prefer, but you don't), so no need to look there...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
xlr8ed
Jan 12, 2007 11:17 |  #3
Manfrotto 680B + 486RC2 = $117 from B&H.
I just got mine and am really happy. Should also fit all of your needs including the ability to shoot portrait.
Rebel XTI
Canon 17-85 - Sigma 70-300 DG APO - Canon 50 1.8
Tamrac Adventure 9
SYS
Gallery: 602 photos
Joined Jul 2004
Jan 12, 2007 11:47 |  #4
See sig below for mine. It's "automatic" feature allows you to quickly adjust the height of the monopod with a simple trigger motion. I use this feature all the time.
-Goethe
dsmgirl
Jan 12, 2007 12:19 as a reply to  @ SYS's post |  #5
Thanks for the replies! So far, I think René is right and all I need is a quick release head. One problem -it doesn't seem to be listed as an opion on B&H's website. Can I use one from another manufacturer? Or could I just get the "3229 Swivel Tilt Head with Quick Release" even though it is only rated for 6lbs? -I assume that if I just don't tilt it when using the heavy lens, it'd be fine(?). Otherwise, the ball head is an option, although I don't know if I'd need/use it and I think I'd rather have the quick release functionality.
Would you agree that the 3229 head would hold up just fine as long as I don't tilt it?
-Erica
Jon
Joined Jun 2004
Jan 12, 2007 12:22 |  #6
I use a head since I'm not using my monopod for things on the straight and level. A ball head allows you to use the monopod at other angles than straight upright, handy if you're on not-so-level hard surfaces. You don't need a pan-type function on a head for a monopod; you can turn the whole monopod. But I suggest the 486RC2, not the 484 - it's heftier and the Bigma will appreciate that. Manfrotto/Bogen does make a simple quick-release. 3299's the old number.
Jon
Cocker Spaniels
primoz
POTN Sports Photographer of the year 2005
Joined Dec 2004
Jan 12, 2007 13:31 |  #7
Personally I don't use head on monopod. It's not really comfortable for me, and I don't have any need for it anyway. I use it only for long lenses (300/2.8 and 400/2.8 ) only, so I can easily survive just with attaching monopod on lens collar. I also don't have need for "disconnecting" monopod from lens all that fast, so I don't have any quick release either. But all this is personal preference only, so it can easily be different for someone else :)
PhotoSI (external link) | Latest sport photos (external link)http://www.photo.si (external link)
sugarzebra
Jan 12, 2007 13:41 |  #8
I use the Manfrotto 680B with 486 CR2 ball head and am very happy with the combination. I tried to go without the ball head at first but the versatility provided by the ball head is worth every penny.
Scott
Website & Blog (external link)
rdricks
Gallery: 13 photos
Jan 12, 2007 13:46 as a reply to  @ sugarzebra's post |  #9
I use a Manfrotto 681B. I am one of the users that does not use a head. It is really personal preference. I am going to put a quick release on the monopod though. I purchased the monopod without a head, figuring I can add a head if I want it. I use a tripod most the time, the monopod is for some hiking. Most the lenses I will use on the monopod will have a tripod collar, so I can use the collar to rotate the camera. Disclaimer: I am not using the monopod for sports/action photography. I can see where a ballhead could be very useful for those subjects.
-Ryan
-Ryan
My Photo Adventure (external link)
2,054 views & 0 likes for this thread, 8 members have posted to it.
2253 guests, 124 members online
