Hey guys
i just did a litte experiment with my 1gig extreme III cf card
the screen on my 1dmkiin said that i had enough space for 151 pictures but i pressed the trigger and filled the card and fitted 301 pictures on it why is this soo out ??
Zilly Cream of the Crop 5,086 posts Joined Jul 2006 Location: uk More info | Jan 12, 2007 13:22 | #1 Hey guys Dom
joegolf68 Goldmember 3,269 posts Likes: 1 Joined Nov 2005 Location: Sacramento CA area More info | Jan 12, 2007 13:28 | #2 Odd. When it said you had space for 151, was that for the same size as when you got 151? If so, as you shot, did it keep readjusting the number upwards? Interesting issue, I will follow to see wht the heck happened. Oh, great camera by the way... my envy is showing! Gear List
Jan 12, 2007 13:34 | #3 ill talk you threw what i did i put the card in the camera and formatted it it gave 151 as the avalible number of shots. i then pressed the button till it hit zero for alot of the numbers it would take the shot drop a frame from the avalible number of shots and then add it back on again. once it was done I went to the folder menu and it showed 301 images in the folder i then formatted in in camera and it went back to saying there was 151 shots avalible. Dom
Reefbone Senior Member 929 posts Likes: 1 Joined Jul 2006 Location: Midwest, USA More info | Jan 12, 2007 13:59 | #4 Zilly wrote in post #2529998 ill talk you threw what i did i put the card in the camera and formatted it it gave 151 as the avalible number of shots. i then pressed the button till it hit zero for alot of the numbers it would take the shot drop a frame from the avalible number of shots and then add it back on again. once it was done I went to the folder menu and it showed 301 images in the folder i then formatted in in camera and it went back to saying there was 151 shots avalible. thanks i love it, its a big step but its got to be done I don't see what was accomplished? Didn't reformatting the card erase all the images. Aren't you right back where you started? Rebel XT, EF-S 17-55IS f/2.8, EF-S 17-85IS f/4-5.6, EF 50 f/1.4, EF 100mm f/2.8 Macro, 580EX, Manfrotto Anchor, I9900
bruce_ Mostly Lurking 15 posts Joined Nov 2006 Location: Canberra, Australia More info | Jan 12, 2007 14:07 | #5 If you are shooting in JPG then it will be due to compression.
Jan 12, 2007 14:14 | #6 shouldnt the size of a jpeg be more predictable than a raw ? but will try Dom
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Jan 12, 2007 16:14 | #7 No, the size of a JPEG is less predictable than the size of a RAW. JPEG files with very little detail are much more compressible than those with lots of colours/details, since JPEG treats nearby colour values as if they're all the same and instead of saying "here's a bit that's FFAABB; here's an FFAABA; here's an FFABBA; . . ." where the numbers are the RRGGBB values of the colour in hex; a JPEG will say "well here's 3 that are about FFAABB", and you lose all the nuances. The "shots remaining" is based on an average file size; ISO settings also affect the reading you'll get, but it's essentially guaranteed to be a wrong value. Jon
Jan 12, 2007 18:18 | #8 interesting should it realy be THAT far out tho Dom
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Jan 12, 2007 20:47 | #9 Zilly wrote in post #2531322 interesting should it realy be THAT far out tho raw results give 146 recorded. quoted maximum at 95 That's not all that far off. I've gotten 700 on a 1 GB that was saying 400 when I started shooting at an air show. Lots of lovely, compressible, blue sky! Jon
lostdoggy King Duffus 4,787 posts Joined Aug 2004 Location: Queens, NY More info | Jan 12, 2007 21:08 | #10 I honesty don't know much about 1D bodies and file format but are you just looking at many files are in the card through a computer and could it be that what you seeing is 149 shots (image files) and 149 .thm files and 3 tag files.
rklepper Dignity-Esteem-Compassion 9,019 posts Gallery: 2 photos Likes: 14 Joined Dec 2003 Location: No longer living at the center of the known universe, moved just slightly to the right. Iowa, USA. More info | Jan 12, 2007 22:25 | #11 You mean there are people who shoot something other than RAW? Doc Klepper in the USA
| Latest registered member was a spammer, and banned as such! 1800 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
