Thread started 12 Jan 2007 (Friday) 14:15
acratech ultimate ballhead question....
nodoubt
Jan 12, 2007 14:15 |  #1
anybody using one ?? if so how do you like it ?? thanks...
40d....
50mm 1.8...tamron 28-75... ef 70-300 IS ....EF 10-22
manfrotto 3021BPRO
linhof PROFI III ball head
wimberly quick release, with a kirk plate
DavidEB
Jan 12, 2007 21:10 |  #2
I am a happy customer. I have the older one (with the oblique clamp running across the ball). Very solid, and easy to clean. Very versatile, easy to get the camera into odd positions, and a perfect match to the gitzo explorer.
If you don't need to shoot at odd angles, the RRS seems even nicer than the acratech, but it's not quite as versatile. Also, I'd recommend buying the RRS body plate for the camera as it has a 1/4-20 thread hole and the acratech plate doesn't.
David
my stuff - [URL="http://www.pbase​.com/davideb"]my gallery - [URL="http://photograp​hy-on-the.net/forum/showpost​.php?p=3928125&postcou​nt=1"]go Rats!
nodoubt
Jan 12, 2007 21:17 |  #3
DavidEB wrote in post #2532099 (external link)
thanks....
40d....
manfrotto 3021BPRO
ScottE
Joined Oct 2004
Jan 12, 2007 22:43 |  #4
I found that it took a little while to get used to because you can't angle very much towards the high side of angled beam. You quickly learn to just loosen the rotating panorama mechanism and turn the upper part of the Acratech while keeping the camera pointed towards the subject. After a while you turn the tripod before set it up so that you will have movement in the direction you arel likely to need it. Also I sometimes set up my tripod centre post on a bit of an angle to give me more latitude in moving the camera.
I have really enjoyed using the Acratech.
1,107 views & 0 likes for this thread, 3 members have posted to it.
1800 guests, 122 members online
