Thread started 13 Jan 2007 (Saturday) 12:04
where to buy plexiglass
hapa ­ mamma
Jan 13, 2007 12:04 |  #1
Anyone know where I can buy plexiglass for my setup? Home depot? Anywhere other than online? Thanks!
gjl711
Jan 13, 2007 12:10 |  #2
Usually your local glass supplier has all kinds of plastics as well though I have seen thin stuff at the Depot. What are you using it for? There might be a better plastic available for your application.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
hapa ­ mamma
Jan 13, 2007 12:14 |  #3
I usually take pics of my son (9 months). I have a white muslin backdrop, but because he's crawling, it often bunches up around him. I thought I could put a piece of plexiglass over the muslin on the ground to keep it in place. Would something else work better?
gjl711
Jan 13, 2007 12:20 |  #4
hapa mamma wrote in post #2534584 (external link)
Plexi is good for that application but plexi is brittle and cracks easily. Try Lexan, it is much more tolerant of abuse and a bit more flexible.
::Gear::
hapa ­ mamma
Jan 13, 2007 12:23 |  #5
okay, where can I purchase it? Do I need to order it online?
gjl711
Jan 13, 2007 12:32 |  #6
hapa mamma wrote in post #2534621 (external link)
I would look at your Home Depot first. I have seen sheets of Plexi there before. It they do not have any, look in the yellow pages under glass supply or glass repair. Lastly, maybe your local art supply store has it as well.
::Gear::
SkipD
Joined Dec 2002
Jan 13, 2007 12:37 |  #7
Look in your phone book (Yellow Pages) for the heading "Plastics - Rods, Tubes, Sheets, Etc.". It's after Pizza.
Skip Douglas
TMR ­ Design
Joined Feb 2006
Jan 13, 2007 12:49 as a reply to  @ SkipD's post |  #8
You can buy sheets of either plexiglass or lexan at home depot but you are limited to the sizes thay have. I believe you can get either in 4' x 4' or 4' x 6' pieces. Anything larger and you need to go to a glass and plactics place or sometimes the companies that make plexiglass signs will have scrap.
Robert
Mikester
Jan 13, 2007 13:47 |  #9
Hi, I just wanted to add this. I while back I was doing some research and found a suggestion to use the plastic "tub surround" material instead of plexiglass. It works great. It is easier to clean than plexiglass and cost MUCH less. It also is lighter. It is also sold had home depot.
Canon 5d, 20d, 17-85 USM, 24-70 L, 75-300 Sigma slow lens, 580EX, lots of lights, Epson 1800, Kodak 1400, A growing credit card bill:D
TMR ­ Design
Joined Feb 2006
Jan 13, 2007 14:01 |  #10
Mikester wrote in post #2534884 (external link)
Are you referring to the frosted plastic used in sliding shower doors?
Robert
brunester
Jan 13, 2007 15:42 |  #11
theres a chain in cali that sells that kinda stuff. its called "Tap Plastics" try looking them up, they also do custom cutting and stuff
-Eric
"Imagination is more important than knowledge." -Einstein
nycgrip
Jan 13, 2007 20:58 as a reply to  @ brunester's post |  #12
i would go with some thing non reflective, to avoid kicks off flash and lights. if you can find something sanded or brushed
Gordeez
Jan 13, 2007 22:30 |  #13
Home Depot. Has them cheap. I bought some for my Fish tank.
Flickr (external link)http://www.flickr.com/​photos/peenut07/ (external link)
gjl711
Jan 13, 2007 22:55 |  #14
nycgrip wrote in post #2536708 (external link)
Plexi or Laxan is real easy to make frosted and non-reflective by wet sanding with very fine grit paper. 400 grit will give a very matte finish and 600 will give a more frosted appearance. It wont look too frosted while wet but let it dry and the frosted look pops out.
::Gear::
hard12find
Jan 13, 2007 23:22 |  #15
Lexan is more impact resistant than Plexi...however will scratch and scuff easier...Jim
20D, 10D, Fuji S-20, Mamiya C220 medium format, Sekonic L-508 meter, 2 alien bee 800's, AB remotes, Sigma 500 HS flash, 70-200 F2.8 L, Sigma 24-70 F2.8 EX DG, lots of glass, lots of stuff,8-)
20,074 views & 0 likes for this thread, 12 members have posted to it.
2555 guests, 91 members online
