Anything I can be doing differently to get sharper images? This gym was particularly dark so I had to go to 1/400 @ f2 - 1600 ISO. You suggestions and critique is welcome!
Jan 13, 2007 17:23 | #1 Anything I can be doing differently to get sharper images? This gym was particularly dark so I had to go to 1/400 @ f2 - 1600 ISO. You suggestions and critique is welcome! My Gear
Kadman Member 79 posts Joined Oct 2006 More info | Jan 13, 2007 17:43 | #2 I think this looks pretty darn good if you are just learning this type of shooting! I typically shoot a bit faster, but only just at 500. Other than the sharpness, the things that jump out at me are: Canon 30D, Canon 50mm f1.4, Tamron 28-75 XR DI f2.8, Lowepro Micro Trekker 200, Cheap Promaster Monopod
harryb49 Senior Member 319 posts Joined Jan 2006 Location: Quincy WA More info | Jan 13, 2007 17:46 | #3 Good response Kadman. I am just starting to shoot basketball and your answers are right on the mark for my needs as well. 5D Mark III, 70-200is 2.8L. 16-35 2.8L II, Canon 24-70 2.8L. Canon 50 1.8. 580EX II
Hurricane_777 Member 223 posts Joined Jan 2006 Location: Taylor, MI More info | Actually, I think sharpness-wise you'll find you'll be okay with that (assuming a reasonable sized print). IMO, I just don't find sharpness as important with indoor sports vs. other types of photography.
Thanks for your comments and suggestions. My Gear
And what is your technique for AI Servo? Do you keep the button depressed th whole time someone is running with the ball? Do you press it in bursts depending on the movement? My Gear
grego Cream of the Crop 8,819 posts Likes: 2 Joined May 2005 Location: UCLA More info | Jan 14, 2007 01:48 | #7 I'd say with your camera, do it in bursts. I do not think its that responsive if you just hold it down for the whole period of following. I think its a little too slow on cameras lower than the 1 series. Go UCLA
Kadman Member 79 posts Joined Oct 2006 More info | Jan 14, 2007 10:44 | #8 I agree, I use it "sporadically" would probably put it best. I don't lay on it the whole time, but I do hold it in during a sequence where there is a breakaway coming at me. Please also note that I use the custom function 4 set to "3" so that I'm focusing with the * button on the back. Have you experimented with this? Canon 30D, Canon 50mm f1.4, Tamron 28-75 XR DI f2.8, Lowepro Micro Trekker 200, Cheap Promaster Monopod
| Latest registered member was a spammer, and banned as such! 1748 guests, 104 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
