SYS wrote in post #2569423
Hmmmm... that's the first time I heard of the filter being stuck on the lens. I wonder if the same thing could happen on Canon 10-22.... Could it be caused by accumulated dirt over long usage without intermittent cleaning?
As for the IQ degradation using the filter, this is also the first time I'm learning about it. You may very well be right, but then I've heard many testimonial to the contrary on this forum. I just ordered a Hoya Pro-1 CPL based on such testimony, so I'm now anxious to find it all out first-hand!! If you're right, then I just spent the most expensive "lens protector"!!
Yes, as you can see from the pictures above, there is a small drop in quality, but it's hardly anything that you can't fix with rudimentary sharpening. Really, in all respects it should be a non-issue. Even with all three filters stacked, the image quality is still good and can get better with sharpening.
I think one of the reasons it got stuck on my 10-20mm is because of the Sigma's EX outer finish, which is kind of a non-smooth coating that isn't slippery, so it held onto the filter. Also, the part of the filter that you have to grab to unscrew the filter does not have the best traction for your fingers, and my fingers slipped many times trying to get the filter off.
Rebel XT, 30D, Sigma 50-500mm, Tamron 180mm, Canon 50mm f/1.4, Sigma 30mm, Sigma 10-20mm
