Thread started 20 Jan 2007 (Saturday) 11:41
Camera problem
IndyJeff
Joined Oct 2003
Jan 20, 2007 11:41 |  #1
I am baffled but, I have an idea of what is causing this. Camera fires fine, add a hot shoe mount flash and the flash won't shoot. The on camera fill flash pops up when you hit the button but, it won't go back down without manually pushing it back down.
I am wondering if maybe the fill flash is stuck and is overriding the hot shoe mount causing the HS flash not to fire.
At one point this morning the HS flash was firing, even when I wasn't hitting the shutter button. It just fired of a sequence of about 6 flashes.
Any ideas or suggestions?
On shooting sports...If you see it happen then you didn't get it.
20droger
Jan 20, 2007 11:52 |  #2
Which camera?
In general, my first suggestion would be to clean your hot shoe contacts on both camera and flash. The current is very small (especially for the program control contacts), and a surprizing small amount of dirt, corrosion, oils, or other film can cause misfiring.
IndyJeff
Joined Oct 2003
Jan 20, 2007 11:59 as a reply to  @ 20droger's post |  #3
It is on my D60 and I have cleaned the contacts on both. I even tried a second HS mount flash and still nothing.
I am wondering if the fill flash is stuck internally and it is causing the camera not to recognize the HS flash is mounted. Make sense?
Woolburr
Rest in peace old friend.
Gallery: 115 photos
Jan 20, 2007 13:32 |  #4
It almost seems like I saw a thread about the same problem...and it was a problem with the on-board flash. I'll see if I can find it again...just don't know if it was here or on FM.
olivia252
Feb 08, 2007 13:58 |  #5
Please can somebody help me, I have tried to connect my cable in to my Canon 300D and it is not registering. I know it's not a problem with the cable as I have bought a new one and that still doesn't work. I have had the camera for over 3 years now and this has never happened before.
If it's a problem with the camera does anyone know what the problem is and also how much it will cost to get fixed? Thank you and look forward (or maybe not!) to your response.
Mark_Cohran
Joined Jul 2002
Feb 08, 2007 14:44 |  #6
olivia252 wrote in post #2675964 (external link)
You've got several answers over on your thread.
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
1,280 views & 0 likes for this thread, 5 members have posted to it.
Camera problem
1690 guests, 140 members online
