Thread started 21 Jan 2007 (Sunday) 14:30
Archiving a few drives - way to printout folder and file lists?
jaypie77
Joined Aug 2004
Jan 21, 2007 14:30 |  #1
I'm about to archive a couple drives of data and want to be able to print out folder and file lists for reference so I don't have to go digging too far to find what I need. Any apps for Mac that can do this? Any simple way to do this? Any ideas will be appreciated.
TeeJay
Joined Jun 2005
Jan 21, 2007 14:38 |  #2
Sorry, don't use Mac's, but could you not just do a simple "screen print" of the folder?
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
jaypie77
Joined Aug 2004
Jan 21, 2007 16:20 |  #3
I guess you could do that, but it's not as "elegant" a solution as I was hoping for. The key here is organization.
Jon
Joined Jun 2004
Jan 21, 2007 16:25 |  #4
ls -lr | lp
from a command prompt? I'm assuming OS X and couldn't swear to the exact switches; IIRC -lr is "long" and "recursive". There's a switch for pr to tell it how many lines/page, but my xNIX is rusty. That's a vertical bar between the "ls -lr" and the "lp", BTW, not a lower case "L".
Jon
Cocker Spaniels
SkipD
Joined Dec 2002
Jan 21, 2007 16:25 |  #5
The PC has a way, using old DOS-style commands, to direct a listing of the files on a drive to a file. That file can then be sucked into Excel or something like that. I would suspect that the MAC has similar capability.
Skip Douglas
AirBrontosaurus
Jan 21, 2007 16:58 |  #6
Advanced user commands... the downfall of the mac ;).
Actually, assuming *.* is still a wildcard for macs (no idea if it is or not), and assuming you're running OSX:
1. Open the Finder window and display the file list you wish to print
2. Click on Edit - Select All
3. Click on Edit - Copy
4. Open a word processing program such as TextEdit and make sure it is set for Plain Text format (e.g. in TextEdit select Format - Make Plain Text)
5. In your word processing program, click on Edit - Paste
6. Print the document
Chris | My Flickr (external link) | AirBrontosaurus.com (external link) | Peleng 8mm Fisheye writeup (external link)
Body
: Canon 5D
Lenses: Canon 24-105mm f/4 L | Canon MP-E 65mm Macro | Canon 85mm f/1.8 |
579 views & 0 likes for this thread, 5 members have posted to it.
2552 guests, 91 members online
