agaupt wrote in post #2631796
I could be totally wrong but I don't think the image resolution from the camera is 72dpi.
Computer screens maximum dpi is 72 dpi, I think photoshop defaults to that setting. A picture with say 500 dpi will look the same as 72 dpi on the computer, the file size will just be much bigger and take longer to load. But if you printed those same pictures the there would be a major difference between the two.
dpi is only really important for printing.
Your camera has a fixed maximum resolution, e.g. 1600x1200 for a 2MP camera. Now the difference is how that image is displayed. Monitors follow the 72dpi rule which means that it only takes 72 dots to cover one inch on the monitor screen. That's why a low-res image is usually good enough for websites. Your printer is capable of much higher (or finer) image quality and people usually follow the 300dpi rule. Why? Because 300dpi is commonly accepted as being "photographic" image quality, i.e. nearly indistinguishable from a film printed photo. So, what does this all mean? Practically, to display a 4"x6" image on a computer screen, all you need is a 288 pixels by 432 pixels image which any sub-megapixel camera can provide. But to *print* a 4"x6" on photo paper, you would need a 1200 pixels by 1800 pixels image which a 2MP camera can produce without any problems. If you try to view the 1200x1800 image on your computer screen, you get that common effect of having scrollbars on the bottom and right side of your Photoshop window because the image is simply too large at 72dpi (in effect a 16.6"x25" "monitor" quality image). Similarly, the 288x432 image on photo paper will only be roughly 1"x1.5" photo at "photographic" quality.
In other words, if you never do 8"x10" prints and only do 4"x6" or even 5"x7" prints, all you really need is a 3MP camera! 5"x7" = 1500x2100 = 3,150,000 pixels = 3.1MP! (hint: that's why I still use D30).
One last tip. If you wanted to print 8"x10" from a 3MP camera, you would need 2400x3000 pixels = 7.2MP in order to print at photographic quality (300dpi). Is it possible to do that with a 3MP camera? Yes! How? Using bi-cubic interpolation process available in Photoshop. That will allow you to "increase" resolution but not necessarily increase detail. The result is acceptable but not perfect.
The JPEG from your 20D should already have done some picture processing like sharpening, de-noise, color/tone adjustments, etc. RAW format has none of that and would require later de-noise, sharpening, color correction, etc. But with JPEG, I suggest you to apply whatever you like and only then resize if you are going to use it on a website.
Another thing. JPEG is a lossy format meaning some detail may be lost as well as it may have compression artifacts. If you edit the image, save the result as a TIFF so that it maintains the exact alterations. If you save it as JPEG once again, you are *again* re-introducing more detail loss as well as more compression artifacts. RAW is lossless format, usually converted to TIFF after adjustments are made with RAW converters.
I hope I answered your question somehow.
