From the Paris beach volley tournament summer of 2006. 20D with Canon 75-300mm. Taken in raw and then CS2. Was boiling hot, had to sit under an umbrella to keep out of the sun. Cant wait to try again next year with my 70-200 2.8 L IS !!
cheers
Ali
alistairksmith Member 218 posts Joined Nov 2006 Location: Boston, USA More info | Jan 31, 2007 12:57 | #1 From the Paris beach volley tournament summer of 2006. 20D with Canon 75-300mm. Taken in raw and then CS2. Was boiling hot, had to sit under an umbrella to keep out of the sun. Cant wait to try again next year with my 70-200 2.8 L IS !! _______________
superdiver Cream of the Crop 9,862 posts Likes: 5 Joined Jan 2006 Location: Ketchikan Alaska More info | Jan 31, 2007 14:34 | #2 Well, the only real problem I have with them is that I would like to see them cropped alot more. It of course would be nicer to have the "peak action" when they are hitting the bal so you can crop close and have the ball in the picture at the same time...but that is a metter of timing which is either a matter of luck and or practice.... 40D, davidalbertsonphotography.com
gparvan Senior Member 788 posts Likes: 1 Joined Oct 2006 Location: Seattle, WA More info | Howdy,
disneydork06 Cream of the Crop More info | Feb 07, 2007 00:40 | #4 I'm jealous you got to see walsh and may play and to also photograph it! what settings were you using to shoot these photos? Ryan
AnzioBake Member 43 posts Joined Aug 2005 More info | Feb 07, 2007 03:48 | #5 I got some good shots (IMO) at the 2005 tournamentin Cape Town (both males and Females. If you want to shoot at 2.8 you will most likely need ND filters to prevent the SS from maxing out ( at least here in Africa you would ). The problem with 2.8 is following the action to get those contact shots, if your focus is a bit out the shallow DOP will mean a wasted shot. I am a volleyball playing so rading the game was invaluable at the event. I could anticipate where the attacks were going to come from, focus on the sand in that area and get the contact shot. it takes some practice. With defensive plays a looser crop is helpful as it means less camera movement to have the everything in the shot. You'll have to do some post capture cropping.
AnzioBake Member 43 posts Joined Aug 2005 More info | Feb 07, 2007 03:50 | #6 Sorry if I sound over critical. I am only speaking from my own experience and know hoe difficult this sport can be to photograph...
| Latest registered member is ANebinger 1150 guests, 179 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
