Thread started 31 Jan 2007 (Wednesday) 14:18
Strange shutter problem with EOS 30D
Daruosha
Joined Nov 2005
Jan 31, 2007 14:18 |  #1
Hi. I have a strange problem with my 30D. Its shutter sometimes doesn't response sometimes or resposne with a long delay (about 1 or more second).
The CF Card activitiy light is off and I'm sure this is not related to the full buffer.
Does anyone encountered with this or simiilar problem?? Do I have to send my honey to doctor?
PLEASE HELP
Gears
http://www.DiaryPixels​.Com (external link)
Jon
Joined Jun 2004
Jan 31, 2007 14:24 |  #2
Is the focus light steady or flickering when this happens?
Jon
Cocker Spaniels
Daruosha
Joined Nov 2005
Jan 31, 2007 14:26 |  #3
In the viewfinder the focus confirm light is ok.
Gears
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Jan 31, 2007 14:34 |  #4
is this with multiple shots where the buffer is full?
Gallery: http://tomyi.smugmug.c​om/ (external link)
Daruosha
Joined Nov 2005
Jan 31, 2007 14:41 as a reply to  @ Tee Why's post |  #5
No. I'me sure the buffer is empty (CF activity light is off)!!
Last few minutes I upgraded the firmware to 1.0.5. But the problem is not solved!
Gears
-MasterChief-
- B E L I E V E -
Jan 31, 2007 14:43 |  #6
do you have a grip, and does it only happen with the shutter release on the grip? i had a similar problem with the 30D but it only happened when i used the shutter release on the grip. took the batteries out and voila, back to normal.
Daruosha
Joined Nov 2005
Jan 31, 2007 14:45 as a reply to  @ -MasterChief-'s post |  #7
No. I don't have a portrait grip. I just use the shutter release button located on the camera!! (I didn't test it with remote control)
Gears
René ­ Damkot
Jan 31, 2007 15:04 |  #8
Does this also happen if you put the AF switch on the lens to 'M'?
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Daruosha
Joined Nov 2005
Jan 31, 2007 15:10 as a reply to  @ René Damkot's post |  #9
aaa! I don't remeber it happens with MF mode on the lens!!
I set the camera to not shoot with out the CF card. Also I use a old and slow CF card. may be this problem related to the slow CF card?
Gears
wannasmaxx
Jan 31, 2007 15:15 as a reply to  @ Daruosha's post |  #10
using it in the cold? My 20d is slow in the cold.
20D, BG-E2, 24-70/2.8L, 70-200/2.8LIS, 430EX
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Jan 31, 2007 15:15 |  #11
could be, maybe a try with a new card is worth it. If that doesn't work, I'd probably would send it in.
TheSteveMadden
Jan 31, 2007 15:19 |  #12
Are you using flash, especially the on-board flash? It might be recycling and won't let you take another flash shot until the flash is ready.
Steve
Canon EOS 5D Mark II, 30D, XT, EF 24-70 f/2.8L, 50 f/1.4, 85 f/1.8, other EF lenses, 430EX, several 580EX II's, Pocket Wizard Plus II's, lighting supports and modifiers, etc etc etc
Website (external link)
Scoen
Jan 31, 2007 15:23 |  #13
My 30D shutter lags in multiple burst with my SanDisk Ultra, I got a Extreme III on order hopefully it helps.. Try raising your ISO all the way up put it on M mode turrn the shutter all the way up and select the largest app. And turn it on MF mode and hold down the shutter, if it lags then you have a prob. with the camera, I would try a different card like "Tee Why" says, before you send it in to canon, are you still in warranty?? Hope so, my 30D did the Err99 thing, canon got my cam out and back to me in 9 days so as long as your still in warranty I wouldn't worry. :) Good Luck
CoenPhotography (external link)
René ­ Damkot
Jan 31, 2007 16:31 |  #14
Daruosha wrote in post #2632624 (external link)
If you are saying it doesn't happen with the AF switch on 'M', then Jon was spot on (second post), and the camera is in One Shot AF and can't lock focus....
(In that case, the green focus conformation light in the viewfinder is not on continuously, but either off or blinking rapidly)
CF card has nothing to do with it, since you state the activity light is off.
Nikolas
Jan 31, 2007 21:46 |  #15
check and see if you have got it on AI servo.
sometimes there is a lag with aiservo till it lock on focus.
Canon 5D2 20D & 300D 50mm f1.8 mk 2, 24-105 f4 IS L
Tokina 12-24 f4
ATX PRO, 400mm f5.6 ATX apo
Sigma 28-70mm f2.8
EX DG, 120-300mm f2.8 EX DG
Tamron SP pro TC 1.4 and KENKO 2x teleplus pro 300DG and lots of m42 lenses
2,706 views & 0 likes for this thread, 11 members have posted to it.
1687 guests, 96 members online
