Does anyone have any helpful tips for separating two 77mm filters which have been screwed together?
I've tried with quite hard with my hands, but too scared to put a lot of pressure on.
Thanks in advance.
Tony_Tog Member 31 posts Joined Jan 2007 More info | Feb 04, 2007 07:38 | #1 Does anyone have any helpful tips for separating two 77mm filters which have been screwed together? _______________
wannasmaxx Goldmember 1,175 posts Joined Oct 2005 Location: London More info | Feb 04, 2007 07:50 | #2 BFH!!!! 20D, BG-E2, 24-70/2.8L, 70-200/2.8LIS, 430EX
sirsloop BigFoot 943 posts Likes: 2 Joined Oct 2006 Location: South River, NJ More info | Feb 04, 2007 07:58 | #3 man... those things are crazy sometimes. You can put all the torque your fingers can muster on then, then release, put very slight pressure at a different angle on and they pop right apart. no gear List
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Feb 04, 2007 08:01 | #4 NEVER squeeze filters with a two-point grip. That makes the filter try to be an oval instead of a square, and does nothing but make the threaded connection harder to turn. Skip Douglas
SteveInKentucky Senior Member 390 posts Joined Jan 2007 Location: Kentucky Lake More info | Feb 04, 2007 08:13 | #5 Tony, Rebel Xti/with grip
Tony-S Cream of the Crop 9,911 posts Likes: 209 Joined Jan 2006 Location: Fort Collins, Colorado, USA More info | Feb 04, 2007 09:10 | #6 Tony_Tog wrote in post #2652387 Does anyone have any helpful tips for separating two 77mm filters which have been screwed together? I've tried with quite hard with my hands, but too scared to put a lot of pressure on. Thanks in advance. Put them on a lens. Hold the lens and filter attached to the lens with your left fingers. Turn the outer filter with your right hand. This seems to work for me (plenty of experience). "Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
Tsmith Formerly known as Bluedog_XT 10,429 posts Likes: 26 Joined Jul 2005 Location: South_the 601 More info | Feb 04, 2007 09:32 | #7 You could try tapping them on a hard surface evenly on the edges, of course protected with a cloth. The vibration can often dislodge stuck threads.
Feb 04, 2007 11:45 | #8 Thanks for your all your help - I've got them loose! _______________
LesterWareham Moderator More info | Feb 04, 2007 11:53 | #9 Put a rubber band around each of them - this will improve grip without having to squeeze too much. Gear List
jr_senator Goldmember 4,861 posts Joined Sep 2006 More info | Feb 04, 2007 12:20 | #10 Don't they make filter wrenches anymore? Tony, get filters with brass rings instead of aluminum and you won't have the seizing problem.
Tsmith Formerly known as Bluedog_XT 10,429 posts Likes: 26 Joined Jul 2005 Location: South_the 601 More info | Feb 04, 2007 23:01 | #11 jr_senator wrote in post #2653513 Don't they make filter wrenches anymore? Tony, get filters with brass rings instead of aluminum and you won't have the seizing problem. I've used aluminum type filters (from the chaepest to most expensive) for 20 years now and have never had to deal with removing a stuck filter _ if you tighten the brass type too hard they can become stuck also.
the.digital.guy Senior Member 442 posts Joined Apr 2005 Location: Pennsylvania,USA More info | Feb 04, 2007 23:14 | #12 Vaseline and WD40 have been used by others I know.They both clean up very well and do no damage to the filter(glass) itself.
ilovemycamera Goldmember 1,338 posts Joined Oct 2006 Location: Southeast Arkansas More info | Feb 04, 2007 23:19 | #13 glad i'm not the only one this has happened to... LOL GEAR: -7D---Canon 24-70mm f/2.8L---Canon 70-[COLOR=black]200 f2.8L IS---Canon 50mm 1.2L---Canon 16-35mm f/2.8L---Speedlite 580 EX---Canon 100mm 2.8 macro---gitzo gt2942---RRS BH-55
Pixel9ine Senior Member 861 posts Joined Aug 2005 Location: Toronto More info | Feb 05, 2007 01:02 | #14 Lester Wareham wrote in post #2653394 Put a rubber band around each of them - this will improve grip without having to squeeze too much. PS Always worth having some rubber bands in you kit bag for this any many other little jobs. Took the words right outta my mouth. Andre B :: gearlist
edrader "I am not the final word" More info | how about a bucket of cold water http://instagram.com/edraderphotography/
| Latest registered member is semonsters 1477 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
