How do you carry this around at weddings? Do you put it on you waist using the belt loop, attach it to a flash bracket, or what? I put mine on my belt but end up fighting the cord all night long. Thanks
jerrybsmith Senior Member 299 posts Joined Jan 2006 Location: Houston, TX More info | Feb 05, 2007 13:57 | #1 How do you carry this around at weddings? Do you put it on you waist using the belt loop, attach it to a flash bracket, or what? I put mine on my belt but end up fighting the cord all night long. Thanks
Toogy "I like pictures of myself!" 6,248 posts Likes: 3 Joined Nov 2003 Location: Ontario, Canada More info | Feb 05, 2007 14:12 | #2 I use mine on my belt, it took a little to get used to, but now I hardly notice it there at all.
LeesaB "Patience is a what? " 14,682 posts Joined Dec 2006 Location: It's just St. Louis now! More info | hmm..I don't wear a belt..so I wonder where I could put it? Do those of you who have this like it? Too bad you can't wrap it around something..like an arm or bag or something else you have to carry? LeesaB
samckitt Member 225 posts Joined Apr 2004 Location: Eastern VA More info | Feb 05, 2007 15:16 | #5 I don't have one of these (yet). But was wondering this. It uses 8 AA batteries, is that correct? Does Canon have anything like this that uses the batteries like the 10D, 20D, 30D & so on use? Seems like that would be much easier. They are rechargeable, higher voltage, could use 2 of those batteries in place of LOTS of AA batteries. Scot
Rellik Senior Member 720 posts Joined Sep 2006 Location: Vancouver, BC More info | Feb 05, 2007 15:37 | #6 samckitt wrote in post #2660105 I don't have one of these (yet). But was wondering this. It uses 8 AA batteries, is that correct? Does Canon have anything like this that uses the batteries like the 10D, 20D, 30D & so on use? Seems like that would be much easier. They are rechargeable, higher voltage, could use 2 of those batteries in place of LOTS of AA batteries. Scot Yes it uses only AA batteries in it. I use some rechargable nimh batteries in them and it lasts a long time. Problem with the canon batteries is that they are Li-ion so they aren't optimal to use as a battery pack for flash use. -Derek 40D, 5D, 5D MK II, 1D Mark III
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Feb 05, 2007 17:50 | #7 The only time I use mine is when I have an umbrella and 550EX mounted on a tripod, the CP-E3 speeds up the recycle time a LOT. The cord's too short to attach to my belt and reach my eye without becoming uncomfortable. There should be an easy way to mount it on the camera, if you don't have a grip you can screw it in, but if you have a grip it doesn't attach. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Philco Senior Member 940 posts Likes: 4 Joined Nov 2005 Location: SandyEggo, CA. More info | Feb 05, 2007 18:07 | #8 I thought I read in the instruction booklet that they don't recommend screwing it directly to the bottom of your camera body because of possible interference or something. I'll have to go back and re-read that. Canon 5D MKIII/Canon 5D MKII/ 70-200 F2.8 IS L / 24-70 F2.8L / 85 F1.2L II/ 35 f1.4L / 135 F2.0L / Canon 600 EX-RT X 2
LeesaB "Patience is a what? " 14,682 posts Joined Dec 2006 Location: It's just St. Louis now! More info | I think I will stick with my batteries...I only have to change twice, so that is not too bad, and I can kinda time it out..we always start with fresh ones.. LeesaB
-MasterChief- - B E L I E V E - 3,188 posts Likes: 2 Joined Mar 2006 Location: Requiem More info | Feb 05, 2007 19:12 | #10 mine stays in one of the pockets of my potn jacket.
damo_ Junior Member 24 posts Joined Nov 2006 Location: Wollongong More info | I keep mine in my back left pocket - after a while you don't even know it's there
Hank2122 Member 238 posts Joined Feb 2006 Location: Los Angeles, CA USA More info | Feb 05, 2007 19:39 | #12 jerrybsmith wrote in post #2659647 How do you carry this around at weddings? Do you put it on you waist using the belt loop, attach it to a flash bracket, or what? I put mine on my belt but end up fighting the cord all night long. Thanks i wear mine on the belt. no tangles at all even with a second body+flash. you can also screw it to the bottom of your grip assuming you have a 20d/30d/xt.
| Latest registered member is Marcsaa 978 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
