Does the A540 support cards over 2GB? (4GB)
bsr5 Hatchling 6 posts Joined Feb 2007 More info | Feb 05, 2007 16:05 | #1 Does the A540 support cards over 2GB? (4GB) -A540-
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Feb 05, 2007 17:43 | #2 No. It won't. Jon
Feb 06, 2007 07:35 | #3 ahh that sucks... -A540-
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Feb 06, 2007 08:53 | #4 Bigger cards won't help the 9 min. limit. And that's only for a single clip; no reason not to make more than one clip, and generally videos will look better if they aren't long, continuous runs but have some zooms, cutaways, and different angles in them. Jon
Feb 06, 2007 09:20 | #5 Jon wrote in post #2664187 Bigger cards won't help the 9 min. limit. And that's only for a single clip; no reason not to make more than one clip, and generally videos will look better if they aren't long, continuous runs but have some zooms, cutaways, and different angles in them. Yes I know that, hence why I said "Filesize limit"... -A540-
MaxZoom Senior Member 316 posts Joined Sep 2006 Location: Dublin, Ireland More info | Feb 06, 2007 14:56 | #6 bsr5 wrote in post #2663863 ...it doesn't use any compression ... On a minor technical note it uses M-JPEG compression which is very low compression compared to MPEG2, DivX, xVid or WMV. The low compression give high quality without excessive processing power in the camera. Uncompressed video would use up over 1.6GB per minute and that is without audio. Max
| Latest registered member was a spammer, and banned as such! 2468 guests, 125 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
