This image starts before I release the shutter for the first shot. I have and idea in my head of what I want in the final image and how it should look. I know I want to have a couple of great action shots in the image. I want to have the goal, ball, and if possible a referee in the image. And of course I want a shot of the coach “coaching.” Getting these shots during the season is the challenge that makes this hobby so much fun. Culling through all the images to narrow it down to the four I used is somewhat of a chore, but also fun. After I have chosen the images to be used, I do whatever post-processing is necessary to ensure they look their best. Then I create the montage. I use Photoshop Elements 3.0.
If you are using Photoshop and do not have “The Photoshop (insert the version of Photoshop you are using here) book for digital photographers” by Scott Kelby, I highly recommend you get a copy. This book has step-by-step instructions for almost everything, including a montage. I will try to paraphrase the instructions so they can be followed.
Open the image you will use as the BACKGROUND IMAGE.
Window<Images<deselect Maximize Mode.
Open the FIRST IMAGE you want to collage with the BACKGROUND IMAGE.
Press “v” (the move tool)
Click and drag the FIRST IMAGE onto the BACKGROUND IMAGE.
Resize the FIRST IMAGE as necessary (grab it by the corners).
Hold down Ctrl and click the Create a New Layer icon. This creates a layer directly beneath your current layer (you now have three layers total.)
Click on the top layer.
Press Ctrl G
Press the letter D
Press the letter G and “enter.”
You should now see the Gradient Picker. Choose the second gradient in the picker.
Click the middle (blank) layer.
Click inside the image where you want the FIRST IMAGE to be totally visible (100% opacity) and drag toward the direction you want it to fade. If you do not like what you see, press Ctrl Z and it will undo what you have done so you can try again.
Now switch to the eraser tool and erase anything that is showing that you do not want like the edges of the FIRST IMAGE. By lowering the opacity of the eraser tool in steps, you can make a smooth transition between the two images. It takes a little practice, but it is not really too hard. Once you have the FIRST IMAGE looking good, open another image and do it again.
I hope this helps.
