Thread started 07 Feb 2007 (Wednesday) 10:31
The Vivitar 285 is back baby!
Gatorboy
Feb 07, 2007 10:31 |  #1
This may have been already posted, but Vivitar has revived the 285!
For those that use flash off-camera, this is great news. Instead of trying to find and buy used ones off ebay, you can get them for under $100 brand new. No need to buy the close to $400 580EX for off-camera use when only manual settings are to be used.
Dave Hoffmann
wazmunstr
Joined Feb 2006
Feb 07, 2007 10:36 |  #2
they need to update that flash. i had one, what a work horse. but E-TTLII is a great invention. at least wireless, or something, lcd screen. haha UPDATE THAT THING VIVITAR!
Instagram // http://www.instagram.c​om/versuspixels (external link)
Curtis ­ N
Master Flasher
Feb 07, 2007 10:54 |  #3
The only updates requires would be a swivel head and a "standard" 1/8 miniplug sync socket. ;)
In the cagegory of affordable off-camera flash units, the Vivitar 285HV is a worthy contender, along with the Sunpak 383. The Vivitar has a zooming head but no swivel. The Sunpak has swivel but no zoom.
Both units have a specified GN of 120 feet, but I suspect this is measured at full 105mm zoom on the Vivitar, which means the Sunpak most likely packs more punch for shooting into umbrellas or other wide-angle work. Edit: Incorrect assumption corrected by Bill.
... and if you thought the 8.5 second recycle time on the Sunpak was bad, try 10.4 seconds on the Vivitar! (Both will do better with NiMH batteries.)
Now if someone would only make a cheap, dedicated automatic flash with AF assist! :rolleyes:
Gatorboy
Feb 07, 2007 11:15 |  #4
For those that may appreciate the 285HV, here is what Strobist wrote about it:
Return of a Classic (external link)
Dave Hoffmann
FlashZebra
This space available
Feb 07, 2007 13:25 |  #5
Curtis N wrote in post #2669712 (external link)
The "old" version of the 285 also had full, 1/2, 1/4, and 1/16 manual power settings (1/8 was missing). Has the new one plugged up the missing 1/8 power hole.
The place that you set the power levels on the 285 was just below the flash head. I found this more difficult to deal with than the Sunpak flash units (Vivitar harder to get at when inside a small softbox, or attached to an umbrella). The 383 has the manual setting on the back of the flash, this is just easier to deal with.
The sync connector on the Vivitar is also a bit more obtuse, so homebrew cable adaptations that make ad hoc studio use easier, are a bit more difficult. Jacks and adapters that will fit in the 383 are available at Radio Shack (but not the Vivitar).
But, the Vivitar is a nice flash, and there is a ton of after market accessories and light modifiers already out there for the flash (far more than for the Sunpak 383).
Enjoy! Lon
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Feb 07, 2007 13:56 |  #6
.......The Vivitar has a zooming head but no swivel. The Sunpak has swivel but no zoom..............
I have a Vivitar 285 -- it is around 25 to 30 years old. True, the flash does not have a swivel head, but if you have the grip, it has a swivel head.
......... Both units have a specified GN of 120 feet, but I suspect this is measured at full 105mm zoom on the Vivitar.............
According to the circulr slide rule on the side, the GN would be 120 at wide angle and 160 at telephoto.
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
Curtis ­ N
Master Flasher
Feb 07, 2007 14:00 |  #7
londuck wrote in post #2670390 (external link)
Aparently not, according to the Strobist review that Gatorboy linked to.
The nice thing about the HV version is that is has a safe trigger voltage. The older versions shouldn't be connected to a modern camera because of their high trigger voltage.
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Feb 07, 2007 14:07 as a reply to  @ Curtis N's post |  #8
How do you identify the HV? Does it have the letters HV as part of the model name? My old unit just says "Vivitar zoom thyristor 285". The last time that I used it, it was taking extra long to charge so I suspect that the capacitor was getting leaky. I may get a new capacitor and bring this bad boy back to life if it is worth it.
Curtis ­ N
Master Flasher
Feb 07, 2007 14:08 |  #9
bill boehme wrote in post #2670533 (external link)
Thanks for that info.
KevC
Joined Jan 2005
Feb 07, 2007 14:11 |  #10
*REALLY* Wow. Now I'm excited.... a couple of these and some pocketwizards, I'm in business! =)
//edit: Okay now I'm getting even *more* excited. PC sync cord to one, wein peanuts to others.. that should work right? Or even the eBay Radio slaves instead of pocketwizards.... (i'd be shooting in studio anyway so i don't need such reliability.)
Too much gear...
take nothing but pictures .... kill nothing but time .... leave nothing but footprints
cdifoto
Don't get pissy with me
Feb 07, 2007 14:12 |  #11
I saw this flash at B&H when I was between it and the Sunpak. I decided on the Sunpak due to the bounce/swivel head. No way could I go without swivel at this point. Plus it's $10 cheaper for the 383 :).
FlashZebra
Feb 07, 2007 15:00 |  #12
KevC wrote in post #2670599 (external link)
Check out the Sunpak 383 also.
And read this great thread (by Lotto) on inexpensive radio slaves and the needed connections:
https://photography-on-the.net/forum/showthre​ad.php?t=273624
Enjoy! Lon
Headcase650
Joined Jun 2004
Feb 07, 2007 21:18 |  #13
... and if you thought the 8.5 second recycle time on the Sunpak was bad, try 10.4 seconds on the Vivitar! (Both will do better with NiMH batteries.):
Yes much better with NiMH, with 2500mAh its down to 4 seconds on all my vivitars.
60D, Canon 18-135 IS, Sigma 10-20 hsm, 24-70 2.8 hsm, 70-200 2.8 hsm, 430EX II, and all the other stuff that goes along with it.
2,055 views & 0 likes for this thread, 8 members have posted to it.
983 guests, 122 members online
