TMR Design wrote in post #2680677
So it's just based on the subject, clothing, accessories, etc.? You use whichever gives you the most contrast?
When chromakey was a fairly new technique for television, blue was chosen because there is virtually no blue in (caucasian) skin tones... it's less troublesome to drop out than green, anyway. I assume movies used blue for the same reason, even though "bluescreen" was an optical film technique, vs. the electronic chromakey of TV. Walter Cronkite has blue eyes, however, so when CBS began to use chromakey as an element in the evening news, they had to use a green screen, or Uncle Walter's eyes would sparkle with the new inserted background image. As mentioned, lighting is critical for either color, as light reflecting off of the background can interfere with a clean mask around the subject. In TV, a complimentary light (e.g. amber) was often used as a backlight to better separate the subject from the background when keying was used.
As the technique advanced, a very specific green was developed for the "Ultimatte" process. That ended up working very well, and the precise color and sharp electronic filters resulted in a very crisp effect.
