24nofear wrote in post #2682555
ok i have the 30d and 430ex. when i take pictures inside i get the exact same shutter speed with flash and without flash is that right?
If you're using Av mode, that's what you'll get. The camera meters for ambient light whether you have the flash on or not. That's what Av and Tv modes are for. If you don't want to use the ambient light, use Manual mode.
also the picture is blinking and has the white blowing out but everything is in the middle of the histogram am I reading it wrong?
Probably. If there are blinky areas there should be a spike on the right side of the histogram. If the blinky areas are large, the spike will he tall. Post a sample if you want a more detailed analysis.
Flash Photography 101 (link in my signature) is fairly short and should help you with some flash concepts. The EOS Flash Bible is much longer but if you want to understand how your camera's flash system works, it's required reading.
