Hi,
Will be visiting parts of Canada soon, and wondering if cold weather will cause any problems with my micro-drive. Would it be better to use a regular compact flash in that climate?
Feb 11, 2007 03:06 | #1 Hi, Canon 6D & 7D. Panasonic GX85 and a number of ever changing lenses.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Feb 11, 2007 10:28 | #2 Yes, it will if you're going to be out for long. Moving parts tend to bind more in the cold and your battery's going to fade sooner regardless of what it's trying to write to. Jon
jr_senator Goldmember 4,861 posts Joined Sep 2006 More info | Feb 11, 2007 12:27 | #3 Some may not want to hear it, but, there are several reasons to use flash drives. And now-a-days it so cheap I can't see going any other way.
pcasciola POTN SHOPKEEPER 3,130 posts Joined Sep 2004 Location: Millstone Township, NJ More info | Microdrives are only rated down to around 32 degrees faranheit (same as many of the Canon DSLRs btw), but many CompactFlash memory cards are rated down to below zero faranheit (-13F for the SanDisk Extremes). Philip Casciola
ScottE Goldmember 3,179 posts Likes: 3 Joined Oct 2004 Location: Kelowna, Canada More info | Feb 11, 2007 22:56 | #5 I have used IBM and Hitachi microdrives in winter conditions with no problems, but a Sony I had was so slow in cold weather that it was unuseable. Generally I use Sandisk Extreme CF cards, but if those get filled up at a ski race I switch to the microdrives I carry for back up capacity.
| Latest registered member is semonsters 1667 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
