Thread started 13 Feb 2007 (Tuesday) 14:50
Snowboarder hitting a rail
Brodog2525
Feb 13, 2007 14:50 |  #1
hello everyone i took this photo, then cropped it a fair amount and did a few other things. i was taking pictures of my friends slidding on this rail which isnt that impressive cause its only 2 feet of the ground but i think i like the mood of this photo. please tell me what you think.
IMAGE: http://brodiehenry.smugmug.com/photos/129250436-L-1.jpg
large photo here (external link)
-brodie
Canon 30D | 17-85mm EF-S with IS | 430EX Flash
50mm f/1.8 II | 18-55mm lens kit
70-200mm f/4 L
brodiehenry.smugmug.co​m (external link)http://www.BrodieHenry​.com (external link)
ramrock4x4
Feb 13, 2007 15:32 |  #2
can you post the original. I personally would like to see more of the rail than of the space to the right
350d (Black) / Opteka Grip/Canon 18-55mm (kit lens) / Canon 50mm 1.8II / Tamron 75-300 4-5.6 LD /
Peleng 8mm / 2 Vivitar 285hv /
3 Pocket Wizards Plus II /
With plenty of filters and hoods to go around
Brodog2525
Feb 13, 2007 16:13 as a reply to  @ ramrock4x4's post |  #3
orginal
70-200mm f/4 L
ramrock4x4
Feb 13, 2007 18:46 |  #4
yah i see theres not much more to work with on the crop, what kind of post processing have you done on this?
CaptainShenanigans
Feb 13, 2007 18:52 |  #5
good start, get down low and shoot at a more extreme angle, that will make the rail seem higher and clean up your background a bit, try to get the light post out of the frame more so it isn't growing out of his back. I like the snow flying a lot, emphasize that.
Canon 5D, 16-35 f2.8, 24-70 f2.8, 70-200 IS f2.8, Canon Speedlight 580EX, Canon Speedlight 430EX, BGE4 battery grip
Chenla ­ Ou
Feb 14, 2007 00:48 |  #6
that looks fun
primoz
POTN Sports Photographer of the year 2005
Joined Dec 2004
Feb 14, 2007 01:24 |  #7
Personally I don't like photos like this. Background is way too cluttered so you have to really concentrate to see boarder. I know it's not possible to do it different sometimes, but in this case you could still do it, and pretty easy too. Just go a bit lower and shoot up so you get sky for background and not parking place with garbage baskets.
PhotoSI (external link) | Latest sport photos (external link)http://www.photo.si (external link)
ramrock4x4
Feb 14, 2007 08:19 |  #8
yah you'll find with extreme sports shots lower will be the set up for most of them.
Brodog2525
Feb 14, 2007 10:33 as a reply to  @ ramrock4x4's post |  #9
this reply is for everyone who posted.
Ramrock-- I first cropped and then did a quick mask to select the snowboarder and then did some kind of blur filter to the background which is why the background is blurry. i sharpen the snowboarder layer. changed levels a little and saturation and then addded vingetting.
Captain- I love the snow flying up too. i would have gotten a lot lower to the snow but it was very cold that day and i was just messing around
Primoz- I was not trying to get some great photos when i took this picture, i was just kinda messing around and having fun. that said, I hate the background in the photos but i have attached another photo without the cluttered background. but everything you said is correct
did anyone notice the shadow on the right side of the photo, i personally like the shadow. anyway heres one at a lower angle.
1/250
f/22
ISO 400
Flash: 430EX
18mm
70-200mm f/4 L
primoz
Joined Dec 2004
Feb 14, 2007 13:48 as a reply to  @ Brodog2525's post |  #10
Much better for my taste, but tilt is thing I don't like on this one. Sorry it's hard to satisfy me :p
CaptainShenanigans
Feb 15, 2007 15:37 |  #11
the horticle almost works in this one, I like how you are trying different angles. I love how the color really pop out. again, watch your backgrounds, I want to see the next frame, maybe where he is over to the right a tad bit more, the image is very heavy on the left (which is perfectly fine as long as you tastefully balance the composition)
(I'm starting to sound like my photo teachers, hehe:)
Big ­ WIll
"Slight breach of etiquette"
Feb 16, 2007 05:03 |  #12
Agree with primoz on this one the tilt is not right IMO! Maybe the same shot without the tilt would work better!
I would look at getting less Depth of field, F22! seems a tad over the top! :) That may make your background OOF and produce a better image.
Computers blur the boundaries... We are being released from the suddenness of photography, the suddenness of the shutterhttp://www.photography​-on-the.net …p?p=1606920&pos​tcount=132
Brodog2525
Feb 16, 2007 10:45 |  #13
Big WIll wrote in post #2717579 (external link)
oh the reason it was f/22 was because of the 430EX flash. the max shutter speed I could get with the flash was 1/250. i used P mode for the 2nd shot but M for the first.
70-200mm f/4 L
dirt ­ lover
Feb 16, 2007 12:05 |  #14
You should try it without a flash (maybe you would need it) with your 50 f/1.8. Then, you could blur the background and probably have high enough shutter with the flash.
You might as well use 100 ISO. You could get a clearer shot and the ability to use a bigger aperture.
Dakine Sequence { 20D | Sigma 10-20 f/4| Tamron 17-35 f/2.8 | Tamron 55-200 f/4 | 3 Vivitar 285HVs | 3 Pocket Wizards }
PBmedia (external link)
Brodog2525
Feb 16, 2007 13:44 |  #15
some of the shots i took that day used the flash, some not. it was overcast that day for some of the time so i used the flash to fill in the face, etc. 50mm on a crop body it way to long. for snowboarding, you need a wide angle which is why i used my 18-55mm. most of the time, i had the lens at 18mm.
70-200mm f/4 L
2,760 views & 0 likes for this thread, 7 members have posted to it.
1519 guests, 131 members online
