Thread started 14 Feb 2007 (Wednesday) 12:04
"Dragging the shutter and using flash"
gateruner
Feb 14, 2007 12:04 |  #1
I have seen this stated a number of times and am wondering if it is essentially 2nd curtain sync flash. If not could someone give me a little better idea on what this means?
Scott { Website (external link) } {Blog (external link)}
5D x 4, Canon 30D x 2, Canon G12, 70-200 2.8L is x2, 17-55 IS, 24-70 2.8L x2, 85 1.2, 50 1.2, Canon 1.4 TX, 18-55 kit lens, Vert Grip x 2, Bogen Pro Mono, 580 EX x 2, 430EX, 28 gig memory, Pelican 1564 & a bunch of older Canon/Pentax stuff
Velu
Feb 14, 2007 12:23 |  #2
It's not essentially second curtain !
Your flash exposes your subject while your shutter stays open in order to capture the ambient light !
Simple, darken your living room, except for a small ambient light in the background. Take a picture of a person, sitting in between you and the light. Use manual mode, select 1/60sec f5.6.
Next, change your settings into 1/8sec f5.6 and shoot !
See any difference ?
Experiment and report ! :)
Rgds
Velu
gateruner
Feb 14, 2007 12:43 |  #3
I will tonight. I was assuming that by setting second curtain on flash that the shutter would open for an extended period and then the flash pop just before the shutter closes. That would give the ambient light and then illuminate the subject. Ill try both methods and see what happens.
These 2 concepts seem like they would be the same but my guess is they will not. I know it would be different with a moving object but what I am seeing referenced is a low light reception and a well lit couple slow dancing.
Curtis ­ N
Master Flasher
Feb 14, 2007 13:04 |  #4
"Dragging the shutter" typically refers to using first curtain flash sync with a somewhat slow shutter speed to capture ambient background lighting. In most cases, the effect would be essentially the same with second curtain sync.
Whether the flash fires at the beginning of the exposure or the end will only make a difference if something is moving.
gateruner
Feb 14, 2007 13:41 |  #5
Thanks Curtis, time to start playing in the dark.
cosworth
I'm comfortable with my masculinity
Feb 14, 2007 13:52 |  #6
Flash freezes the subject, but you get to draw out the back ground and ghost the subject.
Example:
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
1,348 views & 0 likes for this thread, 4 members have posted to it.
2295 guests, 136 members online
