Thread started 14 Feb 2007 (Wednesday) 21:30
580EX Malfunctioning?
SYS
Gallery: 602 photos
Joined Jul 2004
Feb 14, 2007 21:30 |  #1
This past Saturday my wife and I threw a birthday party for my son at a local roller skating place. Knowing that the place is very dark, I took my 580EX and mounted it on my 20D. With about 20 of his friends and his 2nd grade classmates in attendance, I was just going nuts trying to play the host, videotaping, as well as taking pictures so I'm kinda fuzzy on details as to what exactly happened. But one thing for sure is that, just as my son was about to blow out the candles on his birthday cake, something happened with the 580EX. Right after taking the picture, thinking that something's wrong, I looked at the LCD to review the picture, but all I saw was nothing but nearly total dark image. I took another picture, and again nothing but a dark image. I then looked at the 580EX flash's LCD to see that the green power light was gone and the "0.5 0.7 1 1.5...m" line at the bottom was constantly blinking.
Thinking that the batteries needed replacing, I came home and just forgot about it until today. Instead of replacing the flash with new batteries, I thought I'll just try the flash again with the same old batteries. To my surprise, I found that everything's back to normal working condition. So I'm wondering what could have happened that ruined that critical candle blowing shot. It's not the case that I was shooting too rapidly without having given the flash to regenerate its power in between the shots or anything like that.
What had caused the bottom line of the flash's LCD to constantly blink and suddenly stopped working? I did once send this flash unit back to Canon for a repair a few months ago, and I had used the flash sparingly since....
Any clue, anyone?
-Goethe
dgcorner
Feb 14, 2007 21:38 |  #2
Sorry to hear about the "mishap" -- nothing like ruined birthday pics...
Could the temperature changes caused the flash to work that way? It could also have been moisture. It will be a pain to send it in to Canon for repairs if the problem does not occur regularly enough for them to diagnose.
John;)
Believe... Work hard... and it will happen!
SYS
Gallery: 602 photos
Joined Jul 2004
Feb 14, 2007 21:46 |  #3
dgcorner wrote in post #2710696 (external link)
I doubt that the temperature changes had caused the problem as the weather that particular day wasn't all that cold (unlike freezing temp today!!). But since I'm totally clueless, I'll take any theories at this point. :confused:
-Goethe
sapearl
Gallery: 243 photos
Feb 14, 2007 22:08 |  #4
Was your 20D able to autofocus?
I know that with the 5D if there is not enough light for the camera to focus, the shutter won't actuate. The autofocus will measure areas of contrast on the "target" and if these are insufficient it won't get a focus lock and won't take the picture. This may sound like a dumb question, but in all the confusion and noise, did your camera actually "snap" the picture?
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
SYS
Gallery: 602 photos
Joined Jul 2004
Feb 14, 2007 22:17 |  #5
sapearl wrote in post #2710843 (external link)
Yes, the camera did take the picture, and that's how I was able to view it on the 20D LCD. Because of the chaotic atmosphere, I'm not too sure, but the fact that the camera took the photo but the image came out in near total dark, my assumption is that the flash didn't go off. But what baffles me is that I wasn't shooting in rapid succession. And why would the LCD on the flash unit keep blinking?
-Goethe
TheSteveMadden
Feb 15, 2007 09:19 |  #6
SYS wrote in post #2710882 (external link)
According to Page 49 of the manual (Under Troubleshooting), the flash distance scale bars will blink if the flashhead has been tilted down to -7 degrees for macro or closeup flash.
If the entire LCD panel is blinking, it means the wide panel has been pulled out (even a little bit).
This doesn't answer why you got NO flash, though. That might have been due to it not being completely seated in the hotshoe or not tightened down.
Steve
Canon EOS 5D Mark II, 30D, XT, EF 24-70 f/2.8L, 50 f/1.4, 85 f/1.8, other EF lenses, 430EX, several 580EX II's, Pocket Wizard Plus II's, lighting supports and modifiers, etc etc etc
Website (external link)
cdifoto
Don't get pissy with me
Feb 15, 2007 09:25 |  #7
Lens cap on? Flash head tilted down/card pulled out part way?
TheSteveMadden
Feb 15, 2007 09:30 |  #8
cdi-ink.com wrote in post #2712782 (external link)
Lens cap on?
LOL... didn't think of that one.
Steve
iof
Joined Mar 2004
Feb 15, 2007 10:09 |  #9
I think your first instinct was right, and your batteries were too low to charge the flash. After resting overnight, they recovered enough to work, and that very soon you will experience the same problem. Or not and something else is wrong.
Ron.
5D,20D, D60, Elan 7, Canon stuff from the 70's, Pentax stuff from the 60's, other stuff.
SYS
Gallery: 602 photos
Joined Jul 2004
Feb 15, 2007 10:18 |  #10
TheSteveMadden wrote in post #2712766 (external link)
No, the cap was off :p as the problem happened after a bunch of shots were successfully taken.
Let's say that I accidentally tilted the flash head down to -7 degrees and activated the distance scale bars to blink. (I do remember tilting the head down on few occassions when bouncing off the ceiling wasn't appropriate). Obviously the flash is "thinking" that I want macro so it adjusts the amount of light output, but in reality I was standing several feet from my son. Is that why I got dark images? Seems like that's the only explanation as to what could have happened...
-Goethe
SYS
Gallery: 602 photos
Joined Jul 2004
Feb 15, 2007 10:24 |  #11
iof wrote in post #2712950 (external link)
Yes, that possibility did go through my head. I need to look at the manual again to find out if one of the symptoms of low batteries is the distance scale blinking....
It's gotta be either this or that I had accidentally tilted the head down -7. I'm VERY relieved by the good possibility that I'm dealing with a normal phenomenon and NOT something that I'll have to send it to the Canon repair.
-Goethe
TheSteveMadden
Feb 15, 2007 11:01 |  #12
When tilting it down, especially if you press it down to the stop, you will put backward pressure on the hot shoe mounting area. It might have caused a momentary contact misalignment.
Just pay attention and check the mount if it refuses to flash again.
You mentioned that this happened on the candle shot. I shoot a lot of birthdays and as soon as I see the cake coming I turn off my speedlite, go to ISO 1600, f/1.8-2.0 and 1/80-1/120 sec then quicky meter with the cake in front of them and adjust. You can get the most beautiful candle shots with no flash as long as you have a fast prime mounted. If i have control over it, I'll also dim/kill the lights. Shoot RAW as you'll need to dial the temperature down all the way - candles are quite warm. I pre-Focus on the back of the cake, as that will be close enough and af in low light is iffy (at least it was with the XT - the 30D should be better)
Here are some samples... These were all ISO1600 at f/2.5-f/2.8 and some of my first birthday shoots with my XT, but I've learned that a wider aperture and a little more shutter speed will lesses subject motion blur. I think flash would have killed the shot.
Steve
cdifoto
Feb 15, 2007 11:20 |  #13
Adorable girls Steve. :)
SYS
Gallery: 602 photos
Joined Jul 2004
Feb 15, 2007 11:20 |  #14
Thanks, Steve, for sharing your technique for shooting birthday cake scenes. You did very well, especially the first photo!
I usually do not like shooting with the flash (hence my ignorance of the 580EX!;) ), but I calculated that the f/2.8 of my 24-70 will push the ISO to 3200 given the dark environment of the roller skating arena, and even then I probably ended up with lots of blurred shots, so I resorted to using the flash. With 20 kids all over the cake, I knew I had to shoot from a distance, too. Over all, it was a great learning experience. :D
-Goethe
TheSteveMadden
Feb 15, 2007 11:33 |  #15
Thanks, cdi-ink :)
SYS, your f/2.8L should handle it. That first shot was with my 85 f/1.8 at f/2.8, 1/100 sec ISO 1600. Two of the three I took of her had motion blur, one severe, but I got lucky with this one. This has to be one of the most demanding shots due to the dim lighting, speed of the event and lack of do-overs. Now that I have my 30D, I'll have to see what H (ISO3200) can do.
Steve
2,828 views & 0 likes for this thread, 10 members have posted to it.
2297 guests, 135 members online
