I have just started using a multiple canon flash setup. 580EX as master on the camera bracket and 430EX as slave (key) on stand. Currently I am using a hot light to light the bg, but would prefer to use an inexpensive strobe with color filters. I am looking at
A VIVITAR 2800![]()
It is my understanding that I should be able to add any autoflash (like the one above) to the C group of my canon setup and have it fire as a slave controlled by the 580EX. I understand that that the C-group in the canon system is not evaluated for exposure calculations and that its power will have to be set to manual (I am assuming this flash can be set to manual).
Does anyone have any experience using a third canon flash as bg?
Anyone have an untested but likely theoretical answer?
And if you use a three-flash canon system, can you tell me what flash you have used as the C-group?
