Thread started 15 Feb 2007 (Thursday) 22:21
Flash at night too harsh
macobee
Feb 15, 2007 22:21 |  #1
Hi, i have a problem and dont know how to change my settings, here is the description:
Manual mode, Shutter set at 1/80, F4.5 Eos 350D with Kit lens and 430 flash.
used center focal point as that covered the subject
back ground is a large nicely lit ship far away
subject is standing 3 meters away from me in front of boat.
result:
Boat is lit "ok" but subject is totally blown out, how can i adjust my flash to fire less powerfull so that teh person is more natural lit and not washed out?
http://www.flickr.com/​photos/marcoveringa/ (external link)
thekid24
pro-zack-lee
Feb 15, 2007 22:29 |  #2
Ive read somewhere on here that shutter drag might work. What happens is set your shutter to 1second or so and lower your flash output. What should happen is the flash will fire while your shutter is still open, thus letting in more light to lighten up the background, and still allowing the flash to illuminate your subject. I really hope I explained it right. I havent done this yet, but Ill start now:p
Curtis ­ N
Master Flasher
Feb 16, 2007 04:30 |  #3
Generally the way to adjust flash output is with Flash Exposure Compensation (FEC). But we won't know why your subject is overexposed to begin with, unless you post a sample shot and provide EXIF info.
Jim ­ M
Feb 16, 2007 11:58 |  #4
Was the flash set for manual as well as the camera? If so, you will have to manually calculate the flash exposure. Otherwise, if the flash is set to ETTL, it should have exposed the subject properly. The exception is if there was too much ambient light on the subject and it was being overexposed by a light other than the flash.
cosworth
I'm comfortable with my masculinity
Feb 16, 2007 12:03 |  #5
Pull out the little diffuser on the end of the flash. It will help widen the path fo light and soften the blow.
Then make certain that your camera is set to ETTL and FEC is to 0. See if this helps.
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
Don ­ Powell
Joined Nov 2005
Feb 16, 2007 21:09 as a reply to  @ cosworth's post |  #6
I hope that I do not make this sound too confusing, and yes, it would be helpful to know your EXIF. When shooting at night, with a lit subject in the background, cameras and meters can be easily fooled. My approach would have been to spot meter the boat, underexpose this about 1/2 to 1 stop. Set the flash on straight manual, set the lens on the appropriate f stop for 3 meters and set the shutter for that 1/2 to 1 stop under. When using flash as the subjects' main light, the aperture exposes the subject, and the shutter exposes the background. My guess is, ISO 200, f13, 1/30 to 1/125 sec. Harsh flash will not be very flattering, but if you use diffusion on your flash, you need a light meter.
Bosman
Gallery: 6 photos
Feb 16, 2007 22:21 as a reply to  @ Don Powell's post |  #7
Just my two cents....
First and foremost listen to Curtis N !
Now for my humble opinion.....difussion is a great suggestion, but one thing I noticed in your post was you used F4.5, I would stop down to F8, that should help alot with the overexposure and also get you into the "sweeter spot" of the kit lens so you will have a much sharper pic. As far as dragging the shutter that is something that will get the background exposed as well as the subject but that doesn't seem to be your problem or something you asked about.
Joe
Rebel XT with grip
Tamron SP AF28-75mm F/2.8 XR Di LD Aspherical (IF)
Canon 18-55 3.5-5.6
Canon 50 1.8
420EX
Domke
F-3X
Domke F-5XB
macobee
Feb 18, 2007 07:33 |  #8
dear all i am sorry i was away for few days so no chance to reply.
i am sorry i dont have the pic on hand anymore, but do value all your advice and made notes for a next time to try out some of your suggestion.
Thanks,
Marco
1,193 views & 0 likes for this thread, 7 members have posted to it.
2297 guests, 135 members online
