Thread started 16 Feb 2007 (Friday) 06:16
Sync cord for XTI
DaveHelvie
1 post
Feb 16, 2007 06:16 |  #1
I have purchased a couple of monolights to do some portrait work. In setting them I have found there is not a sync outlet on the XTI. Is there a cord that hooks to the hotshoe with a RCA on the other end for the strobe unit?
SkipD
Joined Dec 2002
Feb 16, 2007 06:48 |  #2
DaveHelvie wrote in post #2717717 (external link)
You need a common hotshoe-to-PC adapter. They run about $10 (U.S.) and are available in most decent camera stores. Then, you need a cable for your monolights that has a standard male PC connector on the camera end.
You should check to see what the sync voltage is on your monolight(s) and make sure the camera's switching circuits can handle the voltage.
Are you sure the monolights use an RCA plug for the connection? I have not seen that type of plug used on the monolights I have seen. What brand and model of monolights do you have?
Skip Douglas
FlashZebra
This space available
Feb 16, 2007 11:38 |  #3
You can also get the need inexpensive hotshoe to PC adapter from Alien Bee.
See:
http://www.alienbees.c​om/hardware.html (external link)
Enjoy! Lon
1,561 views & 0 likes for this thread, 3 members have posted to it.
Sync cord for XTI
2296 guests, 135 members online
