Ok I have no idea what I could be doing wrong but I just bought two 580ex the other day and tested them on day one, read through the entire instruction manual carefully and everything worked fine.
Today (literally right now) I have the master (attached directly to my 20D) and I have a slave in a softbox setup. I was trying to test shots by having the master off and only have the slave fire (which worked on day 1). Now I cant get it to work
and its a simple thing to do...
After following the instructions on page 36 of the manual:
"1. Press the <ZOOM/zigzag> button so that the display blinks as shown on the left.
2. Disable the master unit's flash firing.
Turn the <dial> to select <o FF>, then press the <centerdial> button
The <zigzag> icon will blink"
The master still fires I've confirmed that the settings are correct because the little zigzag symbol is blinking and the 3 lines coming from the flash are now gone.
Any thoughts on what I could be doing wrong or what settings I may have on the camera that may be causing this?
I've swapped both unit and changes the settings correctly yet they BOTH still fire... driving myself nuts because I got it to work before!!!
