Thread started 18 Feb 2007 (Sunday) 21:30
POLL: "What position?"
Off
17
27.4%
On-dial disabled
5
8.1%
On-dial enabled
40
64.5%
62 voters, 62 votes given (1 choice only choices can be voted per member)). VOTING IS FOR MEMBERS ONLY.
BROWSE ALL POLLS
5D owners - What position?
orisky
Feb 18, 2007 21:30 |  #1
What position do you leave your on/off switch on the 5D and why? I tend to leave mine On-dial enabled all the time so that I can just hit the shutter button to wake the camera. Curious what others do?
davidfig
we over look the simplest things
Feb 18, 2007 22:21 |  #2
I think mine sits on on-dial enabled. But when I shoot studio once everything is dialed in I may turn it to on-dial disable to make sure I don't change exposure.
5D | 17-40L | Tammy 28-75 2.8 | 28-135 | 50/1.8 | 85/1.8 | Sony A6000 2-Lens Kit | SEL35 1.8 | EF 50 1.8 on NEX as my 75mm 1.8
Mark_Cohran
Joined Jul 2002
Feb 18, 2007 22:56 |  #3
I use a foam lined Haliburton aluminum hardcase for storage, so when my 5D goes into that, it's off (because I'm not going to be getting it out and mounting a lens very quickly anyway). If I'm in the field and shooting, the camera is on, Quick Dial disabled until I need to change the settings.
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
drparker
Feb 18, 2007 23:32 |  #4
Mine is on and enabled unless I put in the bag an extended period
Join us in Chicago on April 22nd (Click here for more details)
5D, 85 f1.8, 24-70L[COLOR=black] f2.8, 70-200L f/4, 580ex, 430ex.
Tareq
"I am very lazy, a normal consumer"
Feb 19, 2007 00:35 as a reply to  @ drparker's post |  #5
I didn't understand the question well enough so that i chose Off.
If i am in using then i keep On-dial enabled, but if i finished my work by it, then definitely turn off.
Galleries:
http://hamrani.deviant​art.com/gallery/ (external link)
Facebook (external link)
I ­ Simonius
Weather Sealed Photographer
Gallery: 19 photos
Location: On a Small Blue Planet with Small Blue People With Small Blue Eyes
Feb 19, 2007 05:12 |  #6
I use in AV mode mostly and after my initial experiences with my first DSLR (20D) I keep the dial disabled because I accidentally changed settings when the dial was enabled. I do change it often to enabled,(AEB or manual) but for the most part default to carrying it not enabled
PROBLEM: with the dial /on/off switch is that carrying the camera ona strap for any time frequently results in the camera either switching itself on or off as the switch rubs on your waist.:evil:
I would argue for a recessed switch in preference to the current design;)
Veni, Vidi, Snappi
Website  (external link) My Gear ---- (external link)
Pete
Feb 19, 2007 05:23 |  #7
I'm the same as Tareq. Leave it switched on while I'm using it, but if it's being put away overnight or for a few days, I'll turn it right off. That means that while it's in the bag, it can't be woken up if something shifts about and presses the shutter button.
That way I can be pretty sure that next time I use the camera, the battery has a good amount of charge.
Pete
UK SE Catch of the Day
Tareq
Feb 19, 2007 05:29 |  #8
Pete wrote in post #2734404 (external link)
Agree, i save the battery charge level by turning off the camera while it isn't in use.
Galleries:
Andy_T
Joined Jan 2003
Feb 19, 2007 05:34 |  #9
Actually, I'm using a 20D, but as the handling on the 5D is identical, I assume my answer has some validity :wink:
I put it on on-dial enabled when using it and putting it away for a short while, but turn it off when it goes back into the camera bag.
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
cataclysmcow
Feb 19, 2007 10:53 |  #10
Mine's always On with dial enabled unless it's packed in a soft case. I see no reason to turn it off since 'off' is really just 'ignore everything but shutter press'. I've never had an issue with bumping the control wheel while shooting, but maybe that's an issue for left eye dominant people.
orisky
Feb 19, 2007 13:24 |  #11
Tareq wrote in post #2733761 (external link)
Sorry, maybe I didn't structure the poll well. I was just curious what position people leave their cameras in when it's not in use. Mine has almost always stayed in the on-dial enabled position, even overnight, and even when I'm travelling. This let's me hit the shutter for instant on. I haven't had an issue with battery drain from accidental on yet.
Tareq
Feb 19, 2007 15:10 |  #12
orisky wrote in post #2736308 (external link)
in that case my choice was correct, i turn it off definitely.
Galleries:
Lorem
Feb 19, 2007 15:12 |  #13
On/Off Doesn't matter. It's not an issue.
John_B
Gallery: 178 photos
Feb 19, 2007 15:42 |  #14
orisky,
I usually leave my camera On-dial enabled, unless I put it in one of my Lowepro bags. Then I turn it off because its usually a bit tight so I don't want it tripping the shutter in the bag :lol:
click to see (external link)
drparker
Feb 19, 2007 18:27 |  #15
3/4 of the time I leave it on with the dial enabled. If I have hard traveling I'll shut it off.
2,986 views & 0 likes for this thread, 13 members have posted to it.
1820 guests, 119 members online
