Thread started 19 Feb 2007 (Monday) 15:12
Photoshop CS2 scratch disk partition size
philmar
Gallery: 130 photos
Feb 19, 2007 15:12 |  #1
I am buying a new PhotoShop dedicated PC.
Am not too sure about what size disk partition to allocate to Photoshop CS2.
I think I am going with 2 x 320GB hard drives (hhmm, barracuda or caviar).
How big of a partition should I set aside for the scratch disk in Drive D?
Or should I buy a third very small disk and dedicate it solely to PS CS2 scratch?
A photo I took HERE published in National GeographicTime on your hands? Then HERE'S plenty more photos to nibble on (external link):
http://https …photos/phil_mar​ion/albums (external link)
or follow me: https://www.instagram.​com/instaphilmarion/ (external link)
coreypolis
Feb 19, 2007 15:14 |  #2
a 36gb 10k rpm raptor would be your best bet.
Photographic Resources (external link) || International Photo Journalist (external link)
Blog (external link)
Seattle Wedding Photographer - Corey Polis Photographer (external link)
philmar
Gallery: 130 photos
Feb 19, 2007 15:26 |  #3
coreypolis wrote in post #2736807 (external link)
a 26gb 10k rpm raptor would be your best bet.
As a disk drive SOLELY dedicated to Photoshop scratch? and in addition to the 2 320 GB drives?
The Raptors are darned expensive - do you suggest I forgo one of the 320gb drives?
Thanks for your reply!! I wonder what improvement I'd get? I know what the cost is....
philmar
Gallery: 130 photos
Feb 19, 2007 15:36 |  #4
an extra $146 for one of those drives. An interesting proposition..... What kind of performance improvement would I get to Photoshop CS2 with that?
coreypolis
Feb 19, 2007 15:46 |  #5
well I'm assuming you were using 1 HD for the OS and 1 for storage of the photos, having the photos used in photoshop and the scrach disk on the same drive doesn't help all that much, so in theory if you have a good, small, fast HD dedicated only for a scratch disk you can fly with your photoshop editing. Assuming you have a good CPU, RAM etc.
You can get them for less if you search around.
philmar
Gallery: 130 photos
Feb 20, 2007 06:50 |  #6
coreypolis wrote in post #2736967 (external link)
But what gains would I have on a system with 4 GB RAM and a E6600 Intel core duo 2.4 Ghz procesor?
In2Photos
Apr 19, 2007 14:21 as a reply to  @ philmar's post |  #7
Bringing up this old thread, sorry.
I am planning to redo my system configuration when I get my external HDD for backup. Currently I have the following:
WD 160GB SATAII
C: drive, 50GB for OS and Apps
D: drive, 50GB for Data
E: drive, 50GB for C Backup
WD 40GB ATA 100 (maybe 133)
F: drive, Data backup
Seagate 200GB
G: drive, Photos
When I get the external I plan to change the system to look like this:
WD 160GB SATAII
D: drive, 100GB for Data
F: drive, Scratch Disk
Seagate 200GB
G: drive, Photos
External 500GB Drive
E: drive, Backup for entire system.
Am I wasting my time by using the 40GB drive as a scratch disk? Do you see a better way to configure it?
Current Gear and Feedback
EOS ­ MAN1
Apr 19, 2007 14:49 |  #8
I think that is the best way to use it. I have my old pc that I will take the 30gig drive out to use for that. I also have 15gig, but I don't know what I will do with that.
BERNARD BRZEZINSKI
- Photography & Consulting Services
- http://www.bernardbrze​zinski.comexternal link | contact: nfo@bernardbrzezinski.​com
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Apr 19, 2007 15:33 |  #9
Re; Raptor for scratch disk.
I have a 73GB Raptor that when I am booted into XP64 it is used ONLY for a PSCS scratch disk.
This set up (faster than a 36GB Raptor) offers very little speed advantage over using a partition on one of my normal data drives (400GB RAID1 and 500GB RAID1)
I have tested, (it's in the workstation speed test thread linked in the PP FAQ)
Theoretically adding a separate scratch drive should offer better boost.. but in my own tests the difference is negligible.
As to the OP's first question a 10GB partition should be enough, but you may want to go 20GB just top be safe.
CDS' HOT LINKS
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Apr 19, 2007 15:38 |  #10
In2Photos wrote in post #3069859 (external link)
WD 160GB SATAII
Seagate 200GB
G: drive, Photos
I don't think you are wasting time with that 40GB drive as scratch disk... but I'm not sure it's the best choice.
It's the slowest drive you have,. by far...
But on the other hand,. where else would you put the scratch disk. The external is a no go, that leaves either the OS disk, or your photo/data drive?
Don't make a separate partition for the scratch on your 200GB photo drive, but once you get this all installed, try moving the primary scratch to the 40Gb and the 200GB and test each. See if it makes any difference.
CDS' HOT LINKS
In2Photos
Apr 19, 2007 15:46 |  #11
CyberDyneSystems wrote in post #3070195 (external link)
Thanks CDS. I will give it a go and see what kind of results I get. One day I might be able to swap the drive for a Raptor.
StealthLude
Apr 19, 2007 15:52 |  #12
Actually, this would be your most expencive and best bet. This is also what I am using (4 GB Ram Disk)
http://www.ncix.com …DISK&manufactur​e=Gigabyte (external link)
Im a big ran of ram drives and would be my #1 pick
Raptor would come in as #2, but is also a VERY good drive. I still have a 36 and 74 gig raptor install in my system as a system drive, which used to be my scratch disk until I came across the ram disk and just got tempted to try it out.
[[Gear List]]
Skype: Stealthlude
StealthLude
Apr 19, 2007 15:54 |  #13
WD 160GB SATAII
Seagate 200GB
G: drive, Photos
WD 160GB SATAII
Seagate 200GB
G: drive, Photos
I also dont see the point of having soo many JOBD drives. All these seperate drives for backup. I would just get a nice hardware raid card and make a fat RAID 5 array or RAID 10. Its good, fast, peice of mind. I also use a NAS system to backup my raid array, since I just HATE doing manual backups to JOBD arrays.
JOBD = just a bunch of drives.
[[Gear List]]
Skype: Stealthlude
In2Photos
Apr 19, 2007 15:55 |  #14
StealthLude wrote in post #3070266 (external link)
So then on top of that board you have to buy the RAM? Sounds muy expensivo, no?
StealthLude
Apr 19, 2007 16:13 |  #15
In2Photos wrote in post #3070284 (external link)
It is expencive, its the most expencive scratch disk ive seen to date lol. You can throw a max of 4 x 1gig ram sticks on it to make a total of a 4GB ram drive.
Its the most expencive option, but its also the fastest. The write speeds are unreal and really take advantage of my Raid 5 setup.
Only reason I bought this setup is because I picked it up used, and wanted to try it out to see for myself. Now that ive tried it, id buy one new if I had to.
Raptor would also be the next best pick, its a freakin fast drive. Fastest you are getting w/o going to a 15,000 RPM SCSI which will cost you just as much as that ram drive to deploy.
[[Gear List]]
Skype: Stealthlude
5,273 views & 0 likes for this thread, 6 members have posted to it.
2584 guests, 172 members online
