Thread started 19 Feb 2007 (Monday) 18:58
580EX & 420EX Question
cgratti
Lord_Malone, your still a newb...
Joined Feb 2004
Feb 19, 2007 18:58 |  #1
I have a 580EX and 420EX, I want to have the 580 fire the 420 without the 580 actually firing. I have searched the manual and found nothing.
I can get both to fire but I just want the 420 to fire and not the 580.
Canon 30D
Canon 10D
Canon 28-105 f/3.5-4.5 II USM
Apple iMac G5
vetkrazy
Feb 19, 2007 19:56 |  #2
Page 36 in your 580ex manual.
Wrap your ass in fiberglass.... You're only young once but you can be immature the rest of your life
http://vetkrazy.exposu​remanager.com/ (external link)
Gerdav43
Joined Sep 2003
Feb 19, 2007 19:57 |  #3
-580 on hotshoe of camera, set to master
-420 off camera set to slave
-Set both to same channel.
-Set to different groups if using ratios (whole other topic)
-On the 580 you should see a picture of the flash just left of the CH box. Hit the ZOOM button until you see the flash where it looks like it's emitting a flash on the screen. The Screen should say ON or OFF. If it says ON, turn the main dial on the flash until it says OFF.
Proceed with your picture taking. You will still see a flash emit from the 580. This is actually the signal to the 420. It will not, or should not, affect you picture. It actually occurs before the shutter release.
Canon 60D
Canon 70-200 F4 L + Sigma 1.4 T-con
Canon 50mm 1.8
Canon Speedlite 580EX/Canon Speedlite 420EX
Lotto
Feb 19, 2007 22:48 |  #4
Take the flashes and place them infront of a mirror, take a picture of both firing in master/slave mode, you will see the master 580 always flash even it is turned off.
5D, 24-105L, 70-200L IS, 85mm Art, Godox
1,012 views & 0 likes for this thread, 4 members have posted to it.
2219 guests, 131 members online
