How do you submit a tear sheat (for credentials at a event)? you obviously can't make a copy of the page, do you request a copy of the tear sheet from the publisher?
firehawk24 Mostly Lurking 12 posts Joined May 2006 More info | Feb 19, 2007 20:59 | #1 How do you submit a tear sheat (for credentials at a event)? you obviously can't make a copy of the page, do you request a copy of the tear sheet from the publisher?
rcg Senior Member 812 posts Likes: 3 Joined Sep 2005 Location: San Francisco Bay Area - California More info | Feb 20, 2007 00:06 | #2 Yes. The publisher should be able to supply a tear sheet. They are used in advertising all the time. Rob
Feb 20, 2007 00:32 | #4 argash wrote in post #2739760 pardon my n00bishness but whats a tear sheet? Its proof that you did work for a publication. (proof) meaning the actual page in the publication that your work is in.
Feb 20, 2007 00:36 | #5 rcg wrote in post #2739706 Yes. The publisher should be able to supply a tear sheet. They are used in advertising all the time. Thank you!
argash Member 83 posts Joined Feb 2007 Location: Austin, TX More info | Feb 20, 2007 02:34 | #6 firehawk24 wrote in post #2739807 Its proof that you did work for a publication. (proof) meaning the actual page in the publication that your work is in. thanks Canon 60D w/grip // EF 50mm f/1.8 mII // EF 28-135mm f/3.5-5.6 IS USM // EF 85mm f/1.8 // EF 70-200 f/4 L
vwpilot Senior Member 592 posts Joined Nov 2004 Location: Maryland More info | Feb 20, 2007 15:31 | #7 If a copy wont work you can get it from the publisher as was stated. I have submitted quite a few copies of tear sheets though as I keep a file of my publishings and I have never had a problem with them being accepted. Just ask who is requesting them if a copy will work or not. Jim Sykes
Feb 20, 2007 16:35 | #8 vwpilot wrote in post #2743123 If a copy wont work you can get it from the publisher as was stated. I have submitted quite a few copies of tear sheets though as I keep a file of my publishings and I have never had a problem with them being accepted. Just ask who is requesting them if a copy will work or not. Thanks for the info!!
| Latest registered member is Thunderstream 1324 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
