Thread started 20 Feb 2007 (Tuesday) 22:51
flash experts, need your help
dave.richards
Feb 20, 2007 22:51 |  #1
So I was playing around a bit with the built-in wireless capabilities of the 580EX's and ran into a couple of problems.
1. I was under the impression that when changing FEC on the master unit it would affect the lighting output of the slave unit as well. This is not the case with mine. What am I doing wrong? Both units are set to ETTL
2. In the manual it says that you can disable the master unit from firing, but allow the slave unit to still fire. When I set the master unit to "oFF", it still fires anyways. Any ideas??
Just got a thought about this...maybe I am seeing the pre-flash? EDIT after more testing it is not the pre-flash I see. I shot into a mirror and can see the flash in the picture.
dave.richards
The Website (external link)
The Blog (external link)
dave.richards
Feb 20, 2007 23:52 |  #2
another thought....I am using CF.4-1....would that make any difference?
dave.richards
Titus213
Feb 21, 2007 00:26 |  #3
Not sure about #1 but I'll bet what you see in #2 is the communications flash. I believe that's how they set the units.
Dave
Perspiring photographer.
dave.richards
Feb 21, 2007 00:46 |  #4
Hmm interesting.....so this may be a very low power flash I am seeing that is used to transmit the data?
dave.richards
René ­ Damkot
Feb 21, 2007 02:25 |  #5
I allways set the 'overall' FEC on camera.
But: from the 580 manual: 'Any flash exposure compensation amount, high-speed sync (FP flash), FE lock, FEB amount, manual flash, and stroboscopic flash settings set with the master unit will all be automatically transmitted to the slave units'.
So no idea there.... Try setting FEC on camera.
The flash you see with 'Master flash off' is the flash used to trigger the slave.
I've read on POTN before that it can be visible in the shot in some scenarios (like the mirror example)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Titus213
Feb 21, 2007 12:33 |  #6
CF4-1 should not make a difference. What is the issue with photos taken with this system? Over exposed, under exposed or wrong ratios for what is set? Perhaps a sample image with a problem would help figure it out.
Dave
dave.richards
Feb 21, 2007 12:36 |  #7
Well, just to test it, I took a picture of my subject at -3 FEC, then changed to +3 FEC on the master unit, shot again, and the picture looked identical to the previous one.
dave.richards
Titus213
Feb 21, 2007 14:36 |  #8
What was the shutter speed, f-stop, camera mode? Can you post an example with exif?
Dave
dave.richards
Feb 21, 2007 15:35 |  #9
ISO 400, f/4, 1/60th, manual mode. I can post an example later when I get home.
dave.richards
PacAce
Joined Feb 2003
Feb 21, 2007 16:16 |  #10
And you said that you're setting the FEC on the flash unit itself, right, and not on the camera?
...Leo
dave.richards
Feb 21, 2007 16:26 |  #11
Yes, on the master flash unit itself
dave.richards
Titus213
Feb 21, 2007 19:32 |  #12
Got me, something's just not right. But I think you already knew that...:lol:
Page 36 of the 580EX manual does have a footnote indicating that the master will flash even when off if it's in a wireless environment...
Dave
dave.richards
Feb 21, 2007 19:54 |  #13
Yea I saw that, thanks. I am going to try again tonight with a different subject. Maybe the subject I was using (a candle on my coffee table) was too small to be able to notice the difference in light output. But FEC -3 should totally be noticable compared to FEC +3 no matter what the subject is, right?
dave.richards
Curtis ­ N
Master Flasher
Feb 21, 2007 20:26 |  #14
dave.richards wrote in post #2751083 (external link)
It should be one heluva difference, as long as your primary light source is flash, not ambient light.
It might help if you posted a few sample images with EXIF info.
1,157 views & 0 likes for this thread
832 guests, 245 members online
