Thread started 21 Feb 2007 (Wednesday) 12:02
Flash questions
fredmitcham
Feb 21, 2007 12:02 |  #1
I have a 30D and 430ex, I can set the flash 1st/2nd curtain sync in the camera (custom function) or in the flash unit, does the custom function in the camera have any effect on the flash or is it only for the built in flash? Also, what metering do you guys use most often with your hotshoe flash, evaluative or average?
fredmitcham
Feb 21, 2007 18:08 |  #2
Well I did some playing around and to answer my own question, no the custom function in the camera does not control 1st/2nd sync curtain in the flash unit. However FEC in the camera does control FEC in the flash unit if the flash FEC is set to 0, if the flash unit has FEC other than 0, this value overrides whatever the camera's FEC setting is.
Curtis ­ N
Master Flasher
Feb 21, 2007 20:12 |  #3
Those are correct answers to your own questions.
As for your final question, I generally use average flash metering when flash is the primary light source, and evaluative for fill flash. Official documentation on the differences between them is scarce, so I don't know why it works better that way. I just know that it does.
fredmitcham
Feb 22, 2007 12:12 |  #4
Curtis N wrote in post #2751168 (external link)
This may sound dumb but I can't figure out how to change the flash metering? Is this done in the flash unit? I also have a couple more questions:
What is the little bottom piece bracket that comes with the flash for (430ex)?
I'm confused about the retractable widepanel on the flash, what is considered 'wide' or when should I use it? I have a 17-55 lens, if I'm shooting at 17mm or 24mm, should I be using the panel?
thanks!
Curtis ­ N
Master Flasher
Feb 22, 2007 12:40 |  #5
fredmitcham wrote in post #2755193 (external link)
Custom Function 14 on your 30D.
It's just a stand for when you use it as a slave.
Without the wide panel extended, the flash will zoom to cover a 24mm lens on a full frame camera, or a 15mm lens on your 30D. So you won't need it with direct flash, but you may want to use it when bouncing, to spread the light more and illuminate a larger area of the ceiling.
fredmitcham
Feb 22, 2007 12:50 |  #6
Thanks!
Wilt
Feb 22, 2007 13:23 |  #7
You expect Canon or anyone else to explain the twisted, secret voodoo of Evaluative metering in their camera logic ? ! ? ! ? ! :rolleyes:
fredmitcham
Feb 22, 2007 18:04 as a reply to  @ Wilt's post |  #8
what about the rest of you, what flash metering do you usually find most effective?
TMR ­ Design
Joined Feb 2006
Feb 22, 2007 18:07 as a reply to  @ fredmitcham's post |  #9
Since I don't fully understand the flash metering I just leave it on Evaluative. I have changed to Averaging and can't say I noticed a difference.
Robert
1,321 views & 0 likes for this thread, 4 members have posted to it.
Flash questions
2250 guests, 128 members online
