Thread started 21 Feb 2007 (Wednesday) 12:04
F4 shots brighter than F2.8?
fredmitcham
Feb 21, 2007 12:04 |  #1
Is it normal that if I take two pictures of the same thing, with flash or not, one at F4 and one at F2.8, that the F2.8 shot is always slightly less exposed/darker (i'm guessing 1/3 stop) than the F4 shot?
Heatseeker99
Feb 21, 2007 12:18 |  #2
What mode are you shooting in? Manual, AV, Tv? Is this a controlled setup with a tripod shooting the same subject, at the same focal length? AWB?
This will help. But in general, no, it shouldn't be any darker.
A.J.
1D mkIII \ 24-105L \70-200 2.8IS II \ 35L \ 85 1.8 \ Kenko 1.4x \ 580EXII \ 430EX + every piece of Nikon/Photogenic equipment imaginable at the studio.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Feb 21, 2007 12:46 |  #3
If all settings, environmentally and the camera settings (i.e. manual mode), are the same, and the only thing that changes is the aperture between the two shots, then the 2.8 should be brighter.
Could you post the two pics using "Go Advanced" and/or post the exif data so we can compare?
Billginthekeys
Billy the kid
Joined Nov 2005
Feb 21, 2007 12:47 |  #4
if you are in full manual, with the same shutter speed, and ISO, then the larger aperture can only make the image brighter.
Mr. the Kid.
Go Canes!
My Gallery (external link)My Gear
what the L. just go for it.
Mark_Cohran
Joined Jul 2002
Feb 21, 2007 12:51 |  #5
Billginthekeys wrote in post #2748831 (external link)
As above. If that's not the case, then your computer is not consistenly processing your photos.
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
ijohnson
Joined Nov 2003
Feb 21, 2007 12:54 |  #6
I will assume you are shooting in Av mode.
Are you sure its not a metering issue? If you are not on a tripod with a subject that isn't moving, the metering would easily change.
Even the tiniest shift could make the light meter change by 1/3 stop.
Also, as discussed with certain lenses, the vignetting at 2.8 could be allowing less light in. This has been noticed with lenses like the 50 1.4 and 50 1.2 where one is brighter (1.2) at the same f/stop.
www.trickoflight.net (external link)
http://www.pbase.com/i​tj12345 (external link)
Original 5D still ROCKS!!!
Woolburr
Rest in peace old friend.
Gallery: 115 photos
Feb 21, 2007 12:56 |  #7
This is a case where some example photos would be most beneficial. Show us what you have...with exif data intact.
Andy_T
Joined Jan 2003
Feb 21, 2007 13:00 |  #8
The question here is ... are the images really always darker on the f/2.8 than on the f/4?
Or did you see that in some cases the f/2.8 images were darker than the f/4 images. As already mentioned, a tiny difference in the light can change metering ... and if your camera did select a longer shutter speed in some cases than in others, it might explain it.
If you get these results consistantly, then something might be amiss with your camera/metering system/lens/...
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
fredmitcham
Feb 21, 2007 13:27 |  #9
I shoot in Av. If the camera is supposed to give an identical shot at F2.8 1/50 and F4 1/25 then mine is not, lens is a 17-55. The F2.8 shots often come out slightly darker, it may not be 1/3 of a stop but the difference is noticable (although somewhat negligible at the same time). When using my 430ex in Av with 1/250 sync the difference is noticable in a different way (they're illuminated a bit different) but I guess thats unavoidable as at F4 (compared to F2.8 ) the flash has to fire brighter so you get slightly more flash lighting/glare/reflect​ions/shadows and less ambient lighting. Correct?
bieber
Feb 21, 2007 14:14 |  #10
The ambient light exposure will be the same either way, but it's possible the flash metering changed slightly.
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
fredmitcham
Feb 21, 2007 14:36 |  #11
bieber wrote in post #2749194 (external link)
Right but what I mean is the flash will have to fire stronger at F4 to get the same exposure as it did at F2.8, so there's more flash light bouncing around which can change the look of the picture, correct?
Tixeon
Joined Oct 2004
Feb 21, 2007 16:18 |  #12
Would your 17-55 lens focal length setting (for the f:2.8 shots) happen to be towards the 55mm range?
Tim
______
Any cat owner will tell you -- no one really owns a cat...
fredmitcham
Feb 21, 2007 16:49 |  #13
Chigger wrote in post #2749800 (external link)
yes
Tixeon
Joined Oct 2004
Feb 21, 2007 17:12 |  #14
For some reason, I read 17-55 & my mind said 18-55. I assumed the kit lens with it's variable max f:stop. My mistake.
Tim
______
RgB
Feb 21, 2007 18:07 |  #15
I did a lens test at different apertures in AV. Each setting from 2.8 up got darker. I used a tripod and shot the in quick succession.
In AV 2.8 should be the brightest.
Daniel Speranza
30D - 580EX II
Lee ND Grad Filters---77mmWide Angle Adapter
10-22mm f/3.5-4.5 USM --- 24-70mm f/2.8L USM
Website (external link) * Flickr (external link) * Gear
4,850 views & 0 likes for this thread, 18 members have posted to it.
1613 guests, 140 members online
