Can you get rid of "noise" if a pic is shot with too high of an ISO? and if so how is the best way? I have photo shop and also the pics are in RAW form. Thank you in advance for the tips!!!
reefergal Goldmember 1,056 posts Joined Feb 2007 Location: Oregon More info | Feb 22, 2007 20:09 | #1 Can you get rid of "noise" if a pic is shot with too high of an ISO? and if so how is the best way? I have photo shop and also the pics are in RAW form. Thank you in advance for the tips!!!
hannaxt Senior Member 367 posts Joined Feb 2007 Location: New Orleans, LA More info | Feb 22, 2007 20:18 | #2 reefergal wrote in post #2757659 Can you get rid of "noise" if a pic is shot with too high of an ISO? and if so how is the best way? I have photo shop and also the pics are in RAW form. Thank you in advance for the tips!!!
5DMKII •EF50mm f1.4 •EF85mm f1.8 • EF100mm f/2.8 ISL • EF17-40mm f/4L •EF24-70mm f/2.8L •EF70-200mm f/2.8 ISL
hiddenforms Goldmember 2,330 posts Joined Oct 2005 Location: New Zealand, Queenstown More info | Feb 22, 2007 21:11 | #3 I use Neat Image and find that is very good to use, you can down load the Demo but your limited to what you can do with it, here the link http://www.neatimage.com/download.html http://www.flickr.com/photos/gilder/
Radtech1 Everlasting Gobstopper 6,455 posts Likes: 38 Joined Jun 2003 Location: Trantor More info | Feb 22, 2007 22:45 | #4 A quick and easy way to get rid of the little green and red flecks of noise (also called "chroma - meaning color - noise", or "color gremlins") is to use the Median filter, but not in the complicated way mentioned in the post above. .
Geo Goldmember 1,690 posts Joined Nov 2006 Location: Miami Springs, FL. More info | Feb 23, 2007 07:02 | #5 Other way to reduce noise in row is in the detail tab increase the luminance smoothing to 40 and reduce color noise to 15, play with this two control flickr
thank you so much for the tips. I will be trying all of them tonight
| Latest registered member is semonsters 1587 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
