Thread started 24 Feb 2007 (Saturday) 14:50
off camera setup
dirt ­ lover
Feb 24, 2007 14:50 |  #1
I'm getting a Vivitar 285 flash. I'm not sure how to set it up.
  • the options:
  • (ttl?) cord
  • infrared
  • old pocket wizards
I could get a 20' cord, but it would probably be ($80?) and it's a cord. I could get one of those no-name eBay transmitters. Does the 285 have a receiver? Would an infrared setup be a huge pain in the ass outdoors for sports? I've been looking for old pocket wizards, but they are hard to find and still expensive.
Dakine Sequence { 20D | Sigma 10-20 f/4| Tamron 17-35 f/2.8 | Tamron 55-200 f/4 | 3 Vivitar 285HVs | 3 Pocket Wizards }
PBmedia (external link)
Curtis ­ N
Master Flasher
Feb 24, 2007 15:21 |  #2
First, please clarify: Is it the 285HV that Vivitar has recently re-introduced? Is this a new unit or a vintage unit?
dirt ­ lover
Feb 24, 2007 15:35 |  #3
It's the HV zoom thyristor, which is the old one, right?
Curtis ­ N
Master Flasher
Feb 24, 2007 16:32 |  #4
According to the information on this web page (external link), the trigger voltage is well within the safe range for connecting to your PC socket.
There is also some info about that unit on this page (external link) of the Strobist blog.
It has a sync socket and comes with a short PC cord. The easiest way to connect it to your camera is with a PC cord (one end to the flash unit's cord, one end to your camera's PC socket). They're available in various lengths at a reasonable cost. Check your local camera shops or the usual internet retailers. with the right adapter cable, it should also work fine with PocketWizards or other radio systems. Also, you could get a slave adapter to connect to either the foot of the flash or the PC cord. But you would need another manual flash to trigger the slave. Connecting any of these things is pretty simple.
It's a non-dedicated flash so a TTL cord would be an unnecessary expense (though it would work). These auto-thyristor flashes metered their own output with their own built-in sensor. The 285HV also has a variable manual mode.
dirt ­ lover
Feb 24, 2007 17:03 as a reply to  @ Curtis N's post |  #5
Why is the 285 HV under Vesta? Isn't it made by Vivitar?
Lotto
Feb 24, 2007 17:10 |  #6
HV version is safe for the 20D.
Cheapest off camera setup is to extend the supplied sync cord. Cut the cord in half and solder in the extension wire in length of your liking.
The Wein Peanut costs about $20, will plug straight into the 285's sync socket. It's a optical slave sensor, so still needs a flash to trigger it, and does not work well under the sun.
There are 2 Ebay tiggers, one is a 4-channel with hot shoe adapter, one is the 16 channel without the hot shoe, both for about $30 each and should work with the Vivitar.
Used PWs are hard to find because they work every time and last forever (well, almost), I wouldn't sell them if I own some thing like that :) However, a new pair Plus II cost $380, ouch.
5D, 24-105L, 70-200L IS, 85mm Art, Godox
dirt ­ lover
Feb 24, 2007 17:32 |  #7
The cutting/adding wire option sounds pretty good.
http://cgi.ebay.com …tem?hash=item33​0091747787 (external link)
There's the 16 channel one.
What is the difference between that and a pocket wizard?
Curtis ­ N
Master Flasher
Feb 24, 2007 18:20 |  #8
dirt lover wrote in post #2767967 (external link)
About $350 ;)
Oh, and quite a difference in range and reliability.
dirt ­ lover
Feb 24, 2007 18:32 |  #9
What's the range on it? What factors would cause it to not fire (not reliable) as opposed to a wizard?
I'm thinking I should do the PC cord extension and get the ebay setup.
dirt ­ lover
Feb 24, 2007 21:03 |  #10
Would I need an attachment when using my wide lens at 17mm? I would also get an omni bounce.
Lotto
Feb 24, 2007 21:27 |  #11
The range on the Ebay trigger is advertized at 100 ft, though most of the user reports are at about half of that. Because of the low price, Ebay ones use cheap materials and "door bell" technology, with poor soldering joints, and subject to surrounding electrical interference. I haven't used a PW before, but all I heard from the PW owners is that, you plug it in, it will fire 100 % of the time. PWs have years of reliable track rocord and are tools of the Pros.
And yeah, the + $350 thingy.
dirt ­ lover
Feb 24, 2007 22:00 |  #12
Yeah. Pocket Wizards would be nice, but the small problem of $350 each...
FlashZebra
This space available
Feb 24, 2007 22:10 |  #13
Check out the Sunpak 383 also. It is $10.00 less expensive than the new Vivitar 285HV, and seems to be just as capable.
See this review by Curtis:
https://photography-on-the.net/forum/showthre​ad.php?t=242847
You should also check out this related thread by Lotto:
https://photography-on-the.net/forum/showthre​ad.php?t=273624
Enjoy! Lon
Modine
Location: Gaffney, S.C., USA. Home of the Big Peach water tower!
Feb 24, 2007 22:22 as a reply to  @ FlashZebra's post |  #14
The eBay transmitters do NOT work well with NiMh batteries. Use alkalines. I have not figured out why this is so, but the ones i inherited from another photographer would not wotk with the rechargeables batteries. Alkaline batteries make them very reliable units.
Just don't drop anything to the floor. They do break easily.
FlashZebra
Feb 24, 2007 22:32 |  #15
Modine wrote in post #2769399 (external link)
I use these inexpensive radio slave units (I have three sets) and I am please with them, and think they are a good value.
And, alkaline cells do work much better (they are 1.5 Volts and NiMH cells are 1.2 Volts), but they are hardly "reliable" regardless of what cells you use with them.
Enjoy! Lon
1,772 views & 0 likes for this thread, 5 members have posted to it.
off camera setup
2257 guests, 128 members online
